lokar center e-brake install
Old Mar 24, 2008 | 09:17 AM
cprstreetmachines's Avatar
cprstreetmachines
Default lokar center e-brake install
this is 66 mustang coupe with a versi 9".
Parts list: lokar staineless e-brake cables, lokar chrome handle and clevis.
rear disc brake set up
made a braket out of 1/8" steel and attached to the existing 9" spring perch braket
routing the lines for the ebrake in the stock locations up to the center lever
next- is finding the correct mounting point for the lever.
one thing that should be done when installing a center pull e brake lever is to reinforce the floor where you will cutting the hole.
Here we show the plate and where it will be welded to the center trans hump for reinforcement.
this is how the boot cover plate will attach to the newly installed reinforment plate.
rear picture of the cables
completed with clevis
now all you need to do is apply undercoat, install carpet and install boot cover.
check out any of our other projects in our project forums:
http://www.cprstreetmachines.com/for....php?board=2.0
Old Mar 24, 2008 | 11:33 AM
cmanf's Avatar
cmanf
Default RE: lokar center e-brake install
Looks good I was planing on doing the Lokar on my 66. It still has drums tho.
mtgldr
Feb 3, 2024 09:00 PM
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
