289 Timing cover's interchangeable ?
Can anyone tell me if the 64,65, & 66 289 timing covers are interchangeable? I'm rebuilding my c4 (64) 289 and need to replace the timing cover/water pump. I assume all 3 years will bolt up, but just to be on the safe side, I need to ask.
Lastly, the water pump that cameoff has the open impeller, with the timing cover question in mind, shoudl I consider anything when replacing that as well? |
RE: 289 Timing cover's interchangeable ?
As long as it doesn't look like this you are ok. this is a 64.5 timing cover.
[IMG]local://upfiles/27838/6FBA991C4648426890D997370E43AC18.jpg[/IMG] |
No, mine does'nt have, what appears to be an extension housing, but it is a 64 casting block and matching timing cover (C40E). I ask this only because the motor was recently rebuilt (previous owner) and the only parts not replaced were the timeing cover and water pump...
| All times are GMT -5. The time now is 06:57 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
