how important is underlayment
Old Mar 25, 2008 | 07:04 PM
Loza_69Mach1's Avatar
Loza_69Mach1
Default how important is underlayment
I ordered my carpet for my 1969 mach1 and i forgot to order the underlayment/ sound deadener for under the carpet..... Is this really important to have under the carpet... does it really help?
thanks again
jr
Old Mar 25, 2008 | 07:10 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Default RE: how important is underlayment
Yes and yes. Order it and be patient.
Old Mar 25, 2008 | 07:20 PM
Loza_69Mach1
ok thanks... i just ordered it...
thanks
jr
Old Mar 26, 2008 | 08:27 AM
AV8ForFun's Avatar
AV8ForFun
I'm planning to use one of the modern sound deadeners like dynamat. Do you still need to have the original style underlayment with this? Will there be fitment problems with the carpet?
Old Mar 26, 2008 | 08:32 AM
Adrenolin's Avatar
Adrenolin
I'm planning on using fatmat or the like as well as the underlayment. Its not that expensive, will added to the heat/noise protection and give a softer carpeting. My understanding is that most of the carpets are slightly oversized and need to be trimmed anyways. Also if there is a fitment issue around the edges due to the carpet being to high from the underlayment I can cut the underlayment back a bit for proper carpet fit.
Old Mar 26, 2008 | 08:35 AM
sixt5's Avatar
sixt5
i wish i put down some of that dynomat or similar because of noise.
Old Mar 26, 2008 | 10:05 AM
andrewmp6's Avatar
andrewmp6
Yeah you need sound deading or buy some ear plugs.The stick on mat type there talking about is a lot better then the oem kind since you can cover spots the factory ones don't.
whatsup62
Aug 29, 2015 01:25 PM
Calizic
Aug 28, 2015 01:46 PM
movielover40
Aug 27, 2015 10:13 PM
jesse1125
AmericanMuscle.com
Aug 26, 2015 02:34 PM
