need a motor
Old Apr 12, 2005 | 02:44 PM
66fastback's Avatar
66fastback
Default need a motor
well this is what I have 66 fastback mustang I bought on the web and paid way to much for with lots of little problems. what was told to me to be a good running 289, smokes like a pig when it gets hot. so I am stuck looking for a motor and based on the fact that I am already in the car to much I was hoping someone out there might have a great deal on a good 289. please let me know I can use all the help I can get!!
Old Apr 12, 2005 | 02:55 PM
fats429's Avatar
fats429
Default RE: need a motor
READING , Feal like taking a ride to delaware county . I got a 302 short block used
Old Apr 12, 2005 | 03:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you want a 289, scroll down to Worm696's thread titled "Question about Price." Maybe you guys can hook up. Otherwise, you might as well get grease under your fingernails and do an overhaul yourself. I tell ya' it is a real good feeling to overhaul an engine, and it actually runs after you are through. You also have so much more stock in your car, because you did it yourself. And, you can add all those power enhancing goodies while you are at it. Any questions about doing it? Ask away. Oh, and excuse my bad manners. Welcome to the site, and if you have pictures of your new found friend, please post some pictures. If you don't know how, ask us.
Old Apr 12, 2005 | 04:09 PM
66fastback's Avatar
66fastback
I think I put my reply in the wrong place, first I would like to say thanks for your help. However as for rebuilding yourself you are right you do feel beter about the project however time is my problem, not to mention I am a mopar guy and don't know alot about ford normal what to do what not to do stuff. and as my first ford I am not happy with it!!!! but hopefully in time I will fix it up
Old Apr 12, 2005 | 04:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66fastback
You are in the exact place to ask questions about your 66 Mustang. I would ask that you ask yourself how much time do you spend in front of the TV? Rebuilding a vintage Mustang is not only mentally challenging, but it is also recreational. It is hard work both mentally and physically. Whether you are a Mopar guy or not is not the issue here. You own a Classic Ford Mustang. If you want to learn how to maintain it, come here often.
Old Apr 12, 2005 | 04:30 PM
1970 mach1's Avatar
1970 mach1
if you would be interested in getting rid of your ford problem contact me.
Old Apr 12, 2005 | 04:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 1970 mach1
I would also be interested in a decent fastback. PM me.
Old Apr 12, 2005 | 05:46 PM
66fastback's Avatar
66fastback
well I am not ready to get rid of the car well yet and besides I pay alot for it. It was suppose to a a nice car solid gt 350 clone and it is a nice body good inside but some rust on the frame not real but bad but enough and now a bad motor. I don't know how much these go for but I would bet i am under it. I will lwt you know if I get to the point of giving up.
Old Apr 12, 2005 | 06:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
If it has a solid body, engines and such are not too expensive to replace,
Old Apr 12, 2005 | 07:45 PM
67coupe's Avatar
67coupe
"not to mention I am a mopar guy and don't know alot about ford normal what to do what not to do stuff."
66fastback
I am or was a Mopar guy too. My father was a founding member of the Ramchargers drag team. When I was young I would play around the garage while my father ,Jim Thornton, Dale Reeker...etc worked on their 49 Plymouth with the 8-2bl 392 Hemi in it. That was long ago.
I have had GM cars also and never really cared to own a Ford. I bought a 69 F100 back in 1978 and have hot rodded it up a little over the years. I was looking for a 69 Dodge Dart to install a 440 in as a play toy when I came across a good deal( I thought ) on a 67 mustang. It already had a 351W in it and with the stroker kits out there I figured it would be a great starting point for a cruiser/hotrod. The smallblock Fords really grow on you after awhile. The 302 that is in my truck was built 15 years ago and it still idles at 30psi and instantly revs over 6,000 as fast as you can press the throttle.
Good luck with your project. I hope it takes afew years less than mine is going to.
