351 cleveland question
Old Apr 12, 2005 | 11:50 PM
cobra427302's Avatar
cobra427302
I ♥ Acer
Default 351 cleveland question
I heard somewhere that you can change a 2 bolt main to a 4 bolt main with only new caps, some drilling, a tapping. is this true? if so are there any sites that describe the process.
Old Apr 13, 2005 | 03:56 AM
drewsky's Avatar
drewsky
Default RE: 351 cleveland question
im not sure but i dont think it would work
Old Apr 13, 2005 | 07:43 AM
Soaring's Avatar
Soaring
I ♥ Acer
http://www.arp-bolts.com/media/pdf_f...9-31_36-37.pdf
Old Apr 13, 2005 | 09:37 AM
dodgestang's Avatar
dodgestang
Its a little more involved than that; but yes.
4 bolt and 2 bolt 351c blocks are the same block one just had more holes drilled in it at the factory.
You will need take it to a machine shop though and aling hone the new caps to the block to make sure that everything fits proprerly other wise you run the risk of destroying your crank.
Old Apr 13, 2005 | 01:21 PM
fats429's Avatar
fats429
yes thats right you can . but with 4 bolt caps . the 2 bolt caps MUST NOT be drilled out for 4 bolt orperation bad I dear makes them weaker ....
I got a book hear and it has this topic covered hear is a quote from Jack Rouush
" Virtually aney 351C can be a prfromer since thare is no diffrence in meaterials or strenght . In fact, the two bolt main block cap is just as good as the 4 bolt main block eaven the caps are equivalentin strenght . So unless you have a 4 bolt main block don't spend the extra bucks for this feature " Jack Roush
S-A design
Ford Performance
By Pat Ganahl
this quote is on page 75
But if you want to do it , the thread is 3/8 16
Old Apr 13, 2005 | 04:08 PM
cobra427302
I ♥ Acer
ok now that i know that it can be done, is tehre a deffinate advantage to be gained form spending the money to do it. i am wanting about 400-500 rwhp and i heard the the 2 bolt block cant hold as much power, which i know akes sense, but any wayu is it worth it??
Old Apr 16, 2005 | 10:56 PM
281GT's Avatar
281GT
While the 351C was a great motor because they breathe so well but the bottom end was less durable than the 351W. A 4 bolt conversion would be a good idea but you MUST use 4 bolt caps and align hone or you WILL destroy the crank. As previously mentioned, drilling the two bolt caps will also not work because they don't have enough material in them and will weakened to the point where failure is garanteed.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
