Rusty Cowl Panel-What would you do??
Old Apr 2, 2008 | 06:10 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Rusty Cowl Panel-What would you do??
Now you see why racin66? When you can see every thing the water test is a bit pointless.
Old Apr 2, 2008 | 06:48 PM
Adrenolin's Avatar
Adrenolin
Default This is what I'm doing.....
Just order the upper and lower cowl replacements. Since its stripped down anyways now is the time to do it. I just got my cowl removed and have the new replacements as well.
BTW... Was talking to a guy today who does body workand he said to not bother re doing all the spot welds when putting it back in. Instead use (grrr I forget the name of it...) ...that body compound you use for attaching sheet metal to a car. He gave me the name of the stuff to use and said it had something like 3000 pound holding power and that he has used it on a couple cars over the last few years. Said its faster, easier and actually stronger then doing all the spot welds. Just something to think about... I'm still going to look into it a bit more but its a great idea if it will work.
Someone else maybe able to suggest brands or opinions on this....
Old Apr 2, 2008 | 06:51 PM
67fastbackshell's Avatar
67fastbackshell
Default RE: This is what I'm doing.....
You can order the upper and lower panels already put together for 350.00 from mustang depot.
Old Apr 2, 2008 | 07:25 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
You're right, no sense pouring water. Money. Time to start pouring money.
Best of luck.
Old Apr 2, 2008 | 07:41 PM
restomod66's Avatar
restomod66
Replace the entire cowl!! Instead of water used compressed air and feel for airflow instead of water leakage!!
Old Apr 2, 2008 | 08:01 PM
67t5ponycoupe
Adrenolin, if you trust the bond the sheet metal together glue stuff then you use it. They didn't put it together from the factory like that an I personally wont touch the stuff. Why would anyone? Welding metal together is a time proven method. This new glue it together becasue it is faster is a bunch of crap. What happens in 10 years when "oh no I guess this stuff doesn't work" happens? I know it won't happen on my car because I won't use it.
Old Apr 2, 2008 | 08:38 PM
john721's Avatar
john721
You have a great head start...the dash is out. Forego the bonding material. Weld it. That's how I did mine...and it's perfect..
http://i183.photobucket.com/albums/x...owlexposed.jpg
http://i183.photobucket.com/albums/x...wercowlfit.jpg
http://i183.photobucket.com/albums/x...wlpainted2.jpg
Old Apr 2, 2008 | 08:53 PM
67fastbackshell
I purchased the units that are already put together from mustangs unlimited. I will weld it to the rest of the car.
Bonding adhesive is for fiberglass only in my opinion.
Old Apr 2, 2008 | 09:01 PM
john721's Avatar
john721
Check your cowl sides as well. Also, your firewall. You're at the point right now where it is easy to get those too..... (my car was very similar to yours when I started...)
http://i183.photobucket.com/albums/x...wlremoved2.jpg
http://i183.photobucket.com/albums/x...npainted-1.jpg
http://i183.photobucket.com/albums/x...ntedwhite1.jpg
Old Apr 2, 2008 | 09:46 PM
67 evil eleanor's Avatar
67 evil eleanor
Looks like someone has seperated it already or at least removedsome of the spot welds.Half of the fun is over. Just replace the areas with the patch Panels and go one step futher than Ford, and PAINT the area. Then spot weld it back together. Thats a better idea.
