Rear end ?
Old Apr 2, 2008 | 07:35 PM
UBY289's Avatar
UBY289
Default Rear end ?
Can anyone tell how much gear oil is in the rear end of my 67 Coupe with a,289 .c4 300 gears. When I check the oil I just fill it till it starts to run out right.
Old Apr 2, 2008 | 08:02 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Rear end ?
That is correct.
Old Apr 2, 2008 | 08:09 PM
baddog671's Avatar
baddog671
Yup, fill it till it starts to run back out the fill-plug. I believe thats roughly 2qts.
Old Apr 2, 2008 | 08:15 PM
67t5ponycoupe
I think it is closer to 4 quarts
Old Apr 2, 2008 | 08:21 PM
67t5ponycoupe
I'm wrong, looks like an 8 inch is 2 1/4 quarts. I stand corrected.
Old Apr 2, 2008 | 08:41 PM
UBY289's Avatar
UBY289
Thanks .So at 2 1/2 quart is 80 oz . I topped my rear up and it took 18 oz .I guess this is not bad,. I have a small leak on the driver side that I will need to fix.
Old Apr 2, 2008 | 11:48 PM
67mustang302's Avatar
67mustang302
Actually now they're starting to reccomend filling trans/diffs so the fluid level is just at the bottom of the hole, but not running out. That way there's not extra oil in there overloading the seals. If it does run out, it's not the end of the earth. The way I see it, is if it's slightly overfilled and does overload the seals, it'll leak out until it stops overloading the seals, and then it's all good.
Old Apr 3, 2008 | 08:10 AM
65Coupester's Avatar
65Coupester
I fill mine with nitrogen. Improves mileage.
Old Apr 3, 2008 | 10:57 AM
crunchyskippy's Avatar
crunchyskippy
ORIGINAL: 65Coupester
Technically - by letting the diff go completelydry, you are filling it with 78% Nitrogen (or whatever the mixture of sea level air is)! Now liquid nitrogen...we may have solved any heat issues dealing with those pesky friction gears.
[sm=nerd.gif]
Old Apr 3, 2008 | 11:04 AM
boogerschnot's Avatar
boogerschnot
wow.. Nitrogen.. Besure that you dont over fill or you may increase wear on the inside of the gears, resulting in a bald band down the middle of the gear.
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
