Trans fluid change.
Old Apr 13, 2005 | 10:36 PM
mach12004's Avatar
mach12004
Default Trans fluid change.
Any idea how many quarts of trans fluid are needed for a simple fluid and filter change. I have a FMX. Thanks in advance
Old Apr 14, 2005 | 12:12 PM
69mach1377's Avatar
69mach1377
Default RE: Trans fluid change.
I can't find my chilton's manual to help you out...
Old Apr 14, 2005 | 03:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
It's right at 2 gallons if you can manage to get the 3-4 quarts out of the Torque converter too. If your torque converter doesn't have a drail plug, one trick would be to drill a small hole in the TC, and do this very slowly to avoid getting metal flakes inside the TC, then after draining it, get an all-metal screw with a neoprene washer on it and plug the hole. Only use a screw just barely long enough to plug the hole.
When filling with Type F fluid, put in a gallon or so, then keep adding a quart at a time, while checking the dip stick beteen each quart addition. When it hits the full level, start the car and go through each gear slowly. Make sure the car is thoroughly warmed up, then check the fluid level again and add if necessary. What I would do, would be to install a drain plug on the pan so that you don't have to remove the pan and replace with a new gasket each time you change the fluid. Check your manual for how often you need to change it, but most are around every 30,000 miles. You can get these kits from most Mustang parts places.
Old Apr 16, 2005 | 11:43 PM
mach12004's Avatar
mach12004
Thanks for the info. I did not drain the convertor( no plug). I just did a filter ,gasket and tailshaft seal. Thanks.HSB
Matt's 95 Stang
Oct 5, 2015 07:16 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:42 PM
