What a mess....
Old Apr 5, 2008 | 07:19 PM
baddog671's Avatar
baddog671
Default What a mess....
Bored, so I thought I'd give you guys some dumb advice. If you start to drain the old gear oil out of your differential, make sure whatever is catching it doesn't tip over, and be there to see it..
About 3 quarts on the basement floor...
What a mess!
Old Apr 5, 2008 | 07:39 PM
ThanksDad's Avatar
ThanksDad
Default RE: What a mess....
Also, if you ever drain your gas tank don't let the drain plug fall into the funnel. It will clog the funnel andgas will pourall over you and the garage instead of into the gas can the now cloggedfunnel is in.
Old Apr 5, 2008 | 07:41 PM
john721's Avatar
john721
oh no.... pardon the pun, but " that stinks".... I left a rag in the garage over a weekend that I had used to wipe up diff. fluid and additive... boy do that sucker stink!
Old Apr 5, 2008 | 08:53 PM
baddog671's Avatar
baddog671
Haha, John, the entire first level of the house smelled like someone sprayed gear oil all over it. It stunk sooo bad haha.
Old Apr 5, 2008 | 09:47 PM
dugan's Avatar
dugan
also, when taking a tire off, make sure you loosen the lugnut and not tighten it so much it brakes the stud..
when changing a fuel filter, dont put it on backwards..
and finally....when changing engine oil ... never ... ever forget to ... put the oil filter on before you try to drive the car[:-]
Old Apr 5, 2008 | 10:23 PM
ThanksDad's Avatar
ThanksDad
Also this one from just this week. When replacing your battery, do not touch the negative ground wire to the positive terminal. Your starter solenoid won't like it.
Old Apr 5, 2008 | 10:27 PM
racin66coupe's Avatar
racin66coupe
AND, when your car overheats, dont take off the radiator cap, wait for the car to cool down first[:@]
that one hurt
Old Apr 5, 2008 | 10:58 PM
dugan's Avatar
dugan
oh oh! i have got another!
when replacing your battery dont touch the socket wrench to the side of the engine compartment while holding onto it with the negitave still hooked up!
your body wont like that too much.
Aixtreme89
72
Jun 15, 2005 04:43 PM
