export bar shag, almost done
Old Apr 6, 2008 | 07:09 PM
bradleyb's Avatar
bradleyb
Default export bar ****, almost done
I am having problems getting the export bar to align.I have the driver side on and 1 bolt in the rear but am having troubles getting the passenger side to align. I can probably lift the car and flex the piece to get it "in" enough - my problem is getting it "back" (I am about 1/4" too far forward). The rear outside shock tower screw is the farthest away - I am about 1/8" away on the outside forward screw.
I hesitate to drill out the holes and have tried lifting the car from all sides. Any ideas? Maybe, I'll try to lift from the transmission to see if it will open it up a bit.
This is about as much fun as the monte carlo bar[:@].We are just finishing up the outsidethe exterior and trying to get it running (tried to start it but having someelectrical issues figuring out the starter switch with theRon Francis kit).Here is a pic of theshock tower and the car. Thanks
[IMG]local://upfiles/34309/9BF139E3915144E9AE3DC9262D7A6AF1.jpg[/IMG]
[IMG]local://upfiles/34309/ABCF31219C8C4DB79097EB699F77FBF8.jpg[/IMG]
[IMG]local://upfiles/34309/071752A98E9F424387B6A8B7B214E200.jpg[/IMG]
Old Apr 6, 2008 | 07:18 PM
bradleyb's Avatar
bradleyb
Default RE: export bar ****, almost done
here is a serpentine pic and a few of the outside, color came out a bit different - it can be anywhere from silver to brown or black depending on the light
still a ways to go but getting there, can't wait to fire it up, not to mention putting a bit of rubber down with the posi unit
[IMG]local://upfiles/34309/A33729BD71C44656890700381AB78C67.jpg[/IMG]
[IMG]local://upfiles/34309/8BBD88786053465A8FC02E91603E7D6F.jpg[/IMG]
[IMG]local://upfiles/34309/DF1AE32759474778A7B513C301D9BEB1.jpg[/IMG]
[IMG]local://upfiles/34309/35478C8AAFA34E98916476DAAF8245B1.jpg[/IMG]
[IMG]local://upfiles/34309/A937BD751016423598E4B6AC8F307F0A.jpg[/IMG]
Old Apr 6, 2008 | 07:52 PM
Stevetra's Avatar
Stevetra
At first I thought you had the wrong brace, but upon closer examination it looks like your MC Bar is deflected. I would put the up on stands, remove the MC Bar and wait a day and see how much it moves.
Old Apr 6, 2008 | 09:05 PM
bradleyb's Avatar
bradleyb
I took the bolts out of the monte carlo bar on the passenger side, do you think it might settle a bit? Maybe I should jack it up across the front centerpiece, where would suggest using the stands? Maybe back on the frame rail underneath the torque box so that it would settle with the shock tower moving forward? Ideas?
Old Apr 6, 2008 | 09:15 PM
stanging's Avatar
stanging
You might have to spread them with a bottle jack and a 2x4, I had to do that when I put mine on(67 w/351c) If you don't have access to a porta-power.
Old Apr 6, 2008 | 10:16 PM
dodgestang's Avatar
dodgestang
That's about how close mine was when I put it in....good pry bar should help get it in.
I would unbolt the back though....those go in last
However letting it sit overnight with two jackstands on the rear of the front frame rail will relax it a bit and it will be about as relaxed as it will get.
Old Apr 6, 2008 | 10:20 PM
Scott H.'s Avatar
Scott H.
Old Apr 6, 2008 | 11:17 PM
bradleyb's Avatar
bradleyb
Thanks guys, I am going to put the jack under the rear part of the front frame rail tomorrow after work and see how it goes!
Old Apr 13, 2008 | 02:42 PM
bradleyb's Avatar
bradleyb
I jacked up the car which did get it to sag a bit. Also, I took the bolt out of the back and loosened the driver side as much as possible. After a few hours yesterday, we finally got to a result (without chipping the paint, there is a little scratch at the base of the cowl piece but you can't really see it with the export bar over it). Between this, the monte carlo bar and TCP sub-frame kit, I am hoping it "rides on rails". If I jack up the car at the front of the Stage1 part, the car works like a teeter totter and is pretty stiff, can't wait to get it rolling
[IMG]local://upfiles/34309/4A312D04D56E41479FCFD265D875FABE.jpg[/IMG]
[IMG]local://upfiles/34309/A2299DC893DE4A06A3FD9A3B2B03CB1E.jpg[/IMG]
[IMG]local://upfiles/34309/849122C5E8124585B131B5AD15824E87.jpg[/IMG]
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
Sep 16, 2015 07:53 PM
