IDLE
Old Apr 7, 2008 | 03:20 PM
1970coupe's Avatar
1970coupe
Default IDLE
Can someone tell me the response diffrenceto having the car idled up vs if its idled low. take off quicker? shiftas strongin the higher gears?
Old Apr 7, 2008 | 04:36 PM
dugan's Avatar
dugan
Default RE: IDLE
i have always wondered the same thing 1970coupe..sorry i cant help but i am interested to see what others will say. i would imagine though that it depends on the engine and the set up (more built the motor is the higher idle? im not sure though)
Old Apr 7, 2008 | 05:17 PM
1970coupe's Avatar
1970coupe
Default RE: IDLE
yeah i wish we could get our answer too
well im just curious because it seems at higher speeds my transmission takes forever to shift. i have a stock 351c 2v if that helps.
Old Apr 7, 2008 | 05:22 PM
kalli's Avatar
kalli
Default RE: IDLE
there's no way a car will make more power when the idle is lower
it'll be the exact same.
i only have suspicions on having the idle low being good (means i don't know for fact):
sounds good, better gas/mileage, more economy friendly, and probably some smoother driving
imagine your idle being at 2000 .... no we're not talking some odd race cars ... ;-)
kalli
Old Apr 8, 2008 | 08:06 PM
dugan's Avatar
dugan
Default RE: IDLE
^^ makes sense to me.
Old Apr 8, 2008 | 08:14 PM
67mustang302's Avatar
67mustang302
Default RE: IDLE
If the idle speed is set too high, the butterflies may have the transfer slots uncovered at idle, and the off idle throttle response will be poor. You can tell this has happened because as soon as you get into the gas to leave a stop, the car hiccups for a second.
Old Apr 9, 2008 | 07:50 AM
69thunder's Avatar
69thunder
Default RE: IDLE
No power advantage. Won't shift any different.
Old Apr 9, 2008 | 11:17 AM
falconfixer's Avatar
falconfixer
Default RE: IDLE
With a high idle you are closer to the stall converter hooking up - so slightly quicker. But not worth doing. Just set it 750 (Spec IIRC). Now, advancing the timing a wee bit - that'll help the launch... as long as it doesn't knock or ping.
A too high idle may cause 'run on' when shutting it off as well.
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
MacSerio
Sep 27, 2015 01:05 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
