starter selenoid problem
Old Apr 12, 2008 | 07:08 PM
RWHEELS's Avatar
RWHEELS
Default starter selenoid problem
I have a 66 mustang 289 auto, and it keeps blowing selenoids, I am on my third one and every time i replace it, it turns over for about 10-15 seconds and then dies out, like the battery is dying and then just makes this buzzing noise from the selenoid. what would make the selenoids only last about 10 seconds?
Old Apr 12, 2008 | 07:17 PM
ninteen66mustang's Avatar
ninteen66mustang
Default RE: starter selenoid problem
what battery do you have?
Old Apr 12, 2008 | 07:34 PM
RWHEELS's Avatar
RWHEELS
Just to let you guys know whatI have done since having this problem, new selenoids(2), starter bench tested, new battery, new starter to selenoid cable, new battery ground cable. both times that I have replaced the selenoid it starts, but only for one or two starts then the selenoid goes bad. Each time it turns over fine and then slowly dies like the battery is going bad, but the battery is new and even with a charger on it the selenoid just makes that buzzing sound.
Old Apr 12, 2008 | 08:42 PM
67 evil eleanor's Avatar
67 evil eleanor
Check the ground.Can be bad.
Old Apr 13, 2008 | 07:43 AM
RWHEELS's Avatar
RWHEELS
I replaced the ground cable, before the last selenoid and no difference, the only time itturns over is with a new selenoid, but only for 10- 15 seconds and then the selenoid dies
Old Apr 13, 2008 | 10:01 AM
Se4mus1's Avatar
Se4mus1
i had the same problem, check the cable running from the right side of the solenoid to the starter, could be caroded and grounding the positive
Old Apr 13, 2008 | 10:02 AM
Se4mus1's Avatar
Se4mus1
almost forgot, check the neutral switch, u might have tripped it
Old Apr 13, 2008 | 10:12 AM
RWHEELS's Avatar
RWHEELS
already replaced the starter cable, it has to be the selenoid, because every time i replace it it immediately turns over they just dont last for more than 10 -15 seconds or one or two starts
Old Apr 13, 2008 | 11:05 AM
67 evil eleanor
If the solenoid isgetting very hot before the breakdown, then their is something causing the highcurrent draw. It may be the starter has shunted and is causing this, or its not lined up correctly and needs a shim.Also check the wire from the solenoid to the starter to see if its getting hot. Sometimes corossioncanbe a problem. If their is any doubt about the quality of thewire, then change it. Also again, check the engine for a good ground strap, if unsure, then add one or change the other out for a new one. An easy way to check for proper engine ground is use a set of jumper cables. You can hook the black to the(-) on the battery and find a clean bolt on the engine to hood the other end (not near the carb) and see if that helps.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
