wheel and tires
Old Apr 14, 2008 | 02:06 PM
66vicky's Avatar
66vicky
Default wheel and tires
i have a 65 mustang with the 200 sprint. and i want to upgrade my stock wheels and tires. so my question is should i up grade to a five lug patern or stay with the four lug and should i up grade to disc brakes? i do plan to plan to to put some performance parts on to boost the hp.
Old Apr 14, 2008 | 02:13 PM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: wheel and tires
Hellow, welcome to the forum.
This question gets asked a LOT. I would do a search for it.
There are a multitude of options, I bet everyone drops in any second and gives an opinion.
if you're planning on performance modes, what types? How much hp are you looking at?
Old Apr 14, 2008 | 02:14 PM
David09sp's Avatar
David09sp
I ended up going to 5 lug, and bought some American Racing Torque Lites, 17x8 on back, 17x7 on front. I would do the brakes first, then tires.
Old Apr 14, 2008 | 03:48 PM
baddog671's Avatar
baddog671
If your looking to upgrade your wheels/tires, you might aswell convert to 5 lug as that will give you a much larger choice on the wheels.
There is a ton of information on this site about front brake conversion to Granada disc. Just look around..
Old Apr 14, 2008 | 04:16 PM
farkedup's Avatar
farkedup
its not an easy task switching to 5 lug (I've done it) and really isn't cheap unless you already have a line for a proper 9" rear at a decent price because buying all the parts new you can drop $1500 quickly.
but these rims are pretty ugly yeah you get more rim options but with all the work it'll take and expense I'd stick with stock. What rims do you have on yours now? I have my old rims/tires sitting in the corner that you could have for a little more than shipping cost unless you're anywhere within driving distance of Kalamazoo, MI then you could pick them up... could be worth it for the tires though.
Old Apr 14, 2008 | 04:37 PM
TexasAxMan's Avatar
TexasAxMan
You should do the swap if nothing more than for wheel selection. Disc's up front will take care of the front end. Start sourcing an 8" for the rear, expect to pay $100-$300 for it.
Old Apr 14, 2008 | 05:06 PM
mySAVIOReigns
There's no reason for this person to get a 9" rearend. The OP has a 200, which will be slightly modified. If the stocker 7.5" won't handle it, an 8" will DEFINITELY handle the amount of power.
There's a lot of options. Check out www.classicinlines.com if you want some cool rims without changing over to 5-lug.
edit...mean comments removed...
Old Apr 14, 2008 | 05:14 PM
ThanksDad's Avatar
ThanksDad
I was only able to find two styles of 4 lug for my 66. I went with American Racing Outlaw II. They look good and they ran about $90.00 each. If I could ever figure out how to post pictures here I would show them to you.
Old Apr 14, 2008 | 05:27 PM
mySAVIOReigns
I have the exact same ones. here's a pic:
http://picasaweb.google.com/Stephena...36095367403602
Although, they look better now cleaned up
Also these as I mentioned:
http://www.classicinlines.com/products.asp?cat=67
Old Apr 14, 2008 | 09:17 PM
66vicky's Avatar
66vicky
thanks eveybody for the ideas, i think im gona stay with the 4 lugs and do a break conversion. im only 17 and dont have the time or money to change out the rear end. But has anybody done front end suspesion work? again im kinda tight on money and i was looking at global west but dont know what would be the best bang for my buck?
