66 cowl repair
Old Apr 16, 2008 | 02:14 PM
firestang66's Avatar
firestang66
Default 66 cowl repair
I had no rustthrough in my cowl but a lot of surface rust and a couple pounds of media from the media blasting. When I spun it on the rotisserie it was a sand storm in my gagage. So I removed all the spot welds (about 110 to 120 of them) I put 4 good sticky wet coats of por-15 on the cowl base and underside of cowl exterior.
Old Apr 16, 2008 | 02:24 PM
firestang66
Default RE: 66 cowl repair
I then replaced the cowl exterior and re-welded the spotwelds with my Mig. Grinding smooth and sealing the seams with 100% polyurathane. The poly is lighter than the original seam sealer and actually adds structural strenth to the uniboby.
Old Apr 16, 2008 | 02:26 PM
firestang66
The more seams that can be strenthened the better.
Old Apr 16, 2008 | 03:12 PM
john721's Avatar
john721
+1 on the POR15 Good Job! I attacked mine the same way...
[IMG]local://upfiles/54210/4767D02992D04CFAAFBAB4DA9F15CCDA.jpg[/IMG]
[IMG]local://upfiles/54210/15EA8BADC5434DBDADAC36FA03079434.jpg[/IMG]
Old Apr 16, 2008 | 06:33 PM
firestang66
A perfect balance.
Old Apr 16, 2008 | 06:39 PM
firestang66
I lucked out finding a clean Colorado car with only a small amount of rust, and a little bodywork.
Old Apr 16, 2008 | 06:44 PM
firestang66
some of the bodywork has been fun, and easy
Old Apr 16, 2008 | 07:27 PM
Shawnb23's Avatar
Shawnb23
I get to do this soon.. I don't think it's going to be to fun Any tips on removing the cowl?
Old Apr 16, 2008 | 08:07 PM
john721's Avatar
john721
It's not as bad as it seems. You can do it on a weekend.
Old Apr 21, 2008 | 11:52 PM
firestang66
Shawnb23, remove the fenders and hood first, then drill out all the spot-welds with a spotweld drill bit. Get them at your favorite toolstore or about $5 at Harbour frieght. I counted at least 110 welds on my 66, and did them all with the same $5 bit. Just be patient.
