Coil direction?
Old Apr 19, 2008 | 05:54 PM
ford65stang's Avatar
ford65stang
Default Coil direction?
Before i screw anything up, I have a newb question.
Does it matter which direction the coil is?
I plan on having it laying on its side, on top of the manifold. will that be ok?
Old Apr 20, 2008 | 02:59 PM
ford65stang
Default RE: Coil direction?
bump[&:]
Old Apr 20, 2008 | 03:11 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Nope.
Yep.
Old Apr 20, 2008 | 03:13 PM
ford65stang
thank you oxnard
have a beer on me [sm=icon_guiness.gif]
Old Apr 21, 2008 | 11:34 AM
TexasAxMan's Avatar
TexasAxMan
Place the coil so that the poles are toward the bottom.
Old Apr 21, 2008 | 12:43 PM
davesanborn's Avatar
davesanborn
It depends on what type of coil you're referring to....
Some aftermarket coils (MSD Blaster as an example) state in their directions that the coil should not be mounted on it's side.
Disregarding this could lead to coil overheating and ignition failure... ask me how I know.
MSD markets a gel filed(as opposed to a standard oil filled) coil that can be mounted in any position.
Dave
Old Apr 21, 2008 | 03:40 PM
jlg2002's Avatar
jlg2002
I believe that the factory coil is mounted on the intake manifold laying lengthwise with the wiring connections facing towards the front of the car. But i've seen them mounted to the front of the left/right head also.
Old Apr 21, 2008 | 07:44 PM
ford65stang
ORIGINAL: davesanborn
Dave
I have the MSD Blaster 2 ......... [:@]
damm you mean i have to go read the stupid instructions now [8D]
hopefully i still have the box
Old Apr 21, 2008 | 10:20 PM
4reboy's Avatar
4reboy
I think your main concern would be mounting it away from places producing a lot of heat, especially with a performance coil. Here's where mine is mounted and I think it is a good accessible position close to the distributor.
Old Apr 22, 2008 | 01:03 AM
ford65stang
looks like a good spot to me
thanks for the pic
