Rear Tire size??
Old Apr 21, 2008 | 04:47 PM
67fastbackshell's Avatar
67fastbackshell
Default Rear Tire size??
What is the widest tire you can fit on the rear of a 67 fastback before cutting into the wheel wells??
I will be using different wheels and new axles. I ahvent decided yet, so all options are open. I will most likely go with whatever will allow me to use the largest rear tire.
If i need to extend the wheels wells then i can. I will just eliminate the backseat and put a fiberglass cover over it like the original 65 shelbys had.
I might do that anyway since the backseat is somewhat useless.
Old Apr 21, 2008 | 08:28 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: Rear Tire size??
go to the FAQ and look at Dodgestang's tyre and wheel chart.
depending on wheel width and back spacing i think 265 is possible without mods or maybe with rolling thelip a little.
Old Apr 21, 2008 | 09:10 PM
jspagna1's Avatar
jspagna1
I would play it safe and go with a 255. Plenty of tire for the car without going overboard.
Old Apr 21, 2008 | 09:44 PM
67fastbackshell
MIght not be enough tire fora 408W What was Unique using on their cars??
Old Apr 22, 2008 | 11:51 AM
davesanborn's Avatar
davesanborn
Unique Performance standard rear tire size was a 275/40/17. Optional up to 315 with minor tubbing.
You're right in that minor tubbing will make it more difficult to fit the rear fold-down, it's far easier to install the "rear seat delete" 65-66 Rcode FG shelf.
The 275 tire is plently of tire for a 408W.... unless your intentions are to try and break traction. You can break traction with any size tire you run.... you just have to find that "sweet spot" on your RPMs where the most power is transmitted to the wheels without breaking traction.
Dave
Old Apr 22, 2008 | 02:27 PM
67fastbackshell
275 is good. if they will fit then i will be content.
So, i can make the 65 or 66 fiberglass seat delete shelf fit in the 67 without too many problems???
Old Apr 23, 2008 | 09:42 AM
davesanborn
Yes, and in my opinion this is your best/easiest option.
If more than one person wants a ride.... they can go build their own car if they don't feel like waiting for the front seat to open up.
Dave
Old Apr 23, 2008 | 09:50 AM
dodgestang's Avatar
dodgestang
ORIGINAL: davesanborn
Dave
This is exactly the reason why my 65 only has a driver side seat belt
Old Apr 23, 2008 | 09:57 AM
68EFIvert's Avatar
68EFIvert
I have 255/40 18's on my 68 Convertible right now. I have about 3/4 to 1 inch clearance on both sides. I am going to try to fit a 285/40 18 on there once my wider rear wheels come in. Should be in about 2-3 weeks. I don't think I will have problems with the 285's but if I do I will settle with 275's.
Old Apr 23, 2008 | 11:43 AM
zmetalmilitia's Avatar
zmetalmilitia
I have 285-40-17's on mine and they fit good. I did roll the rear fender though to gain a little extra clearance. I have about 1/2" -3/4" clearance on the inside.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
