Intake Removal
Old Apr 21, 2008 | 06:39 PM
scuf23's Avatar
scuf23
Default Intake Removal
Any trick to remove an intake that has been sitting on the engine for about 28 years? got all the bolts loose but it won't move
Should I use the engine lifting plate and try to lift with my hoist?
Allideas are welcome!
Old Apr 21, 2008 | 06:44 PM
cmanf's Avatar
cmanf
Default RE: Intake Removal
I have a dead blow hammer for those occasions. I broke a aluminum intake with the old prybar method thats why I bought the coated dead blow hammer.
Old Apr 21, 2008 | 07:27 PM
baxsom's Avatar
baxsom
ORIGINAL: scuf23
that might not be a bad idea
i used a breaker bar through the front where the thermostat housing was
Old Apr 21, 2008 | 10:01 PM
Starfury's Avatar
Starfury
I'm going to assume it's cast iron since it's 28yrs old and say go ahead with a breaker bar.Even if you can get a large screwdriver in between themanifold and block right in the front, you should have enough leverage.
But yeah, no breaker bar on an aluminum manifold. Dead blow hammers are your friend there.
Old Apr 21, 2008 | 10:09 PM
flyingfool's Avatar
flyingfool
mabeye spray some penetrant around the edges and see if it seeps in and breaks some of the crud loose?
Old Apr 21, 2008 | 10:34 PM
dodgestang's Avatar
dodgestang
6 inch spackle blade use it to break the seal between the intake and the heads.
Old Apr 21, 2008 | 10:59 PM
HyphyDrivah's Avatar
HyphyDrivah
A large screwdriver worked for me. Its heavy so be careful lifting it out.
Old Apr 22, 2008 | 08:27 PM
jfdfire2's Avatar
jfdfire2
I used a large prybar in the thermostat housing. Popped right off.
Old Apr 23, 2008 | 07:53 AM
69thunder's Avatar
69thunder
ORIGINAL: scuf23
All good ideas and tips, intakes do stick down pretty good so it may take a little more effort than you thought. Good luck.
Old Apr 23, 2008 | 11:10 PM
TheRebel's Avatar
TheRebel
Do you have access to a cherry picker or some kind of overhead hoist? You can bolt a chain to the carb studs or some of the accs holes on the intake and then take it off. Before I had a cherry picker I would take the thermostate housing off and put a pry bar in the hole and pop it off.
[align=left] [/align]
