Timing Chain???
Old Apr 22, 2008 | 08:28 PM
66 FastBach's Avatar
66 FastBach
Default Timing Chain???
replacing my front crank seal and wondering about the timing chain. it is very snug on one side and kinda loose on the other, this normal or should it be tight all the way around??
Old Apr 22, 2008 | 08:58 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Timing Chain???
should be snug on both
Old Apr 22, 2008 | 10:35 PM
66 FastBach
time to replace then.
Old Apr 22, 2008 | 10:37 PM
67mustang302's Avatar
67mustang302
No, it may be slightly loose on the unloaded side. When the crank turns it pulls the chain on one side of the cam sprocket, and the other side realxes some. Still though it should be very minimal slack on one side, and hard as a rock on the other(if it's been loaded from the engine running). The question, is how much slack is on the loose side?
Old Apr 23, 2008 | 07:49 AM
69thunder's Avatar
69thunder
+1 it will be tighter on one side if it still has pressure on it. Turn the engine backwards and see if it equalizes the chain. It should.
Old Apr 23, 2008 | 10:11 AM
jfdfire2's Avatar
jfdfire2
If you are in there I would replace it.
Old Apr 23, 2008 | 10:41 AM
TexasAxMan's Avatar
TexasAxMan
As cheap as they are go ahead and replace it. I would never go in that far and leave the old one unless I had personally installed it and knew it's age.
Old Apr 23, 2008 | 12:58 PM
67mustang302
That's true, if the setup has miles on it and you're already there, might as well replace it with a good double roller.
Old Apr 23, 2008 | 05:55 PM
66 FastBach
i can turn the unloaded side atleast 1/2 turn. i'm ordering 1 today. thanx 4 the info.
mungodrums
Oct 7, 2015 04:01 AM
Golfsito
Oct 6, 2015 11:02 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
Sep 8, 2015 11:50 AM
