Another AOD question
Old Apr 23, 2008 | 08:51 PM
outlaw66's Avatar
outlaw66
Default Another AOD question
Hey guys. I finally got the AOD and 5.0L dropped in last weekend. Everything went smooth, other than my finger getting caught between the frame mount and motor mount (ouch!). I proceeded to hook everything up, and found that the Throttle Valve Cable from the Lincoln just might work. Has any body tried this? I'd get a Lokar, but I'm on a VERY tight college budget, and I have todo whatI canto save cash. Any help will really be appreciated. Also, if any body has recommendations on the best tutorial for adjusting the cable, I'd appreciate that also. Thanks in advance.
Old Apr 23, 2008 | 09:21 PM
Daze's Avatar
Daze
Default RE: Another AOD question
the only way to know is to see if you can make it work. Just make sure you set it up correctly and get the correct fluid pressure so you don't burn up the trans.
Old Apr 23, 2008 | 09:38 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
http://www.txchange.com/aodadj.htm [/align]
Old Apr 24, 2008 | 09:43 PM
7tMach's Avatar
7tMach
I just put one in my 72 rag. It had a 302/c4. Pulled that put 351c/AOD. I did by the Lokar and did use there little tool to adjust. But I feel it was best adjusted when I put together a pressure gause set up and adjusted it that way. Read a lot about this and was not sure I made the right decision. But now that I have this thing dialed in..........looking for another to put behind my 351w in my 69 Grande. Pressure is the key.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
