Stripped Header Bolt
Old Apr 24, 2008 | 09:21 AM
6t9 stang's Avatar
6t9 stang
Default Stripped Header Bolt
One of my header bolts was being stubborn while installing my new set... Well in the process of trying to get it out so I could rethread it I stripped the damn thing. I have tried using vice grips and a brake line wrench; I figured if I could grab it from more sides I could get it out. NO DICE.
Not sure what else to try. I know they make those drill bits that you place in a small drilled out hole and the it grabs. however, I dont know if I hae enough room to fit a drill in between the shock tower and the header.
Old Apr 24, 2008 | 09:54 AM
boogerschnot's Avatar
boogerschnot
Default RE: Stripped Header Bolt
ouch.. That sucks.. I know thta craftman has what looks like a socket that instead of having walls on the inside for turning the bolt head there is a reverse bit that bites in to the bolt head and turns it, but there has to be a little bit of head there to bite into.. the set is only about $12 at sears.. That would fit in the space given.. or your going to have to drill/tap it out.
Old Apr 24, 2008 | 10:17 AM
JMD's Avatar
JMD
Also you can get a 90 degree drill or a 90 degree adapter for a standard drill.
This may give you the room you need.
I have seen an addapter at Lowes just a few days ago.
Old Apr 24, 2008 | 10:20 AM
Stepman's Avatar
Stepman
If the head is just rounded, maybe a slightly smaller socket (metric maybe) or craftsman makes socket just for that purpose.
Old Apr 24, 2008 | 10:36 AM
dnswwood's Avatar
dnswwood
The two things I did when I had this problem a few years ago was get a small pipe wrench,not a monkey wrench ..a small PIPE wrench.Then I heated the bolt up with a propane torch.It Came right out.Now I was lucky and it was the one on the very front and was easy to get to .If you can't get to it with a pipe wrench try heating it up and using the vice grips again.You would be suprised what a little heat can do.
Hope this helps
Jeff
Old Apr 24, 2008 | 12:02 PM
Norm Peterson's Avatar
Norm Peterson
If it gets really desperate, there are a couple of rather extreme methods if you have access to a MIG welder.
You could try welding a nut onto the bolt head or bolt stub (probably have to put the weld bead inside the hole in the nut).
Or you could cut the header flange on both sides of the bolt so you can at least get the header out of the way and give you a little more room for other options, such as trying to spin the little piece of flange that's still bolted down by using a hammer and chisel and letting the friction between the underside of the bolt head and the flange piece then turn the bolt a little.
If it's the header that you're replacing, and if it is in fact headed for the trash bin you wouldn't even have to worry about welding the flange back up and getting the head-side surface flat enough to seal.
Norm
Old Apr 24, 2008 | 08:09 PM
6t9 stang's Avatar
6t9 stang
well the problem with using a one of the craftman sockets you guys were talking about is that the bolt is on one of the middle tubes so it is pretty tight; I dont know If a socket will fit on it.
Old Apr 24, 2008 | 09:36 PM
7tMach's Avatar
7tMach
Weld another nut as suggested. The additional heat from welding will help break it free.
Don't be shy with the heat. Just do not melt the sides of the nut. If this happens you could be back in the same boat. This is a very common practice I promote. Been in the welding supply business for near 30 years. It works. And cheaper than Sears.
Old Apr 25, 2008 | 02:10 AM
Stepman's Avatar
Stepman
Well, then you could either cut the head off and remove the header then it will come out with your fingers, or you could try a hammer and sharp chisel.
Old Apr 25, 2008 | 09:54 AM
JMD's Avatar
JMD
No matter what path you take it is going to suck.
If you can get a die grinder in well enough to grind the head of the bolt off this may be an option. Of course this will leave you with the shank of the bolt still screwed into the head, but chances are it will probably not be stuck once the head is off, and you will have better access to weld a nut in place if it is still tight.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
junior04
Sep 28, 2015 10:53 AM
wraith777
Sep 28, 2015 10:49 AM
GLOCKer
Sep 28, 2015 07:36 AM
