Sandblasting is Cool!
Old Apr 26, 2008 | 10:18 PM
palerider's Avatar
palerider
Default Sandblasting is Cool!
Finally tried sandblasting using a pressurized tank I bought from Harbor Freight. All I can say isthant I'm hooked.Curently stripping my engine bay and have tried bristle brushes, wire wheels, andairplanestipper. All I can say is that sandblasting rocks - messy but rocks!
Old Apr 26, 2008 | 11:14 PM
Nick.Simonds's Avatar
Nick.Simonds
Default RE: Sandblasting is Cool!
Can I ask what your using to blast? When I bought my stuff from them, i used the glass bead they had on hand. When I ran out they told me to use play sand.....
Old Apr 26, 2008 | 11:16 PM
palerider's Avatar
palerider
Black silica 80 grit
Old Apr 26, 2008 | 11:18 PM
ky's Avatar
ky
America ftw
ORIGINAL: Nick.Simonds
its harbor freight my friend. dont expect any good.
i just bought a DA sander from them tonight. its seems to be holding up ok so far.
Old Apr 26, 2008 | 11:19 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you are using a respirator right??
if not stop and get one
as for using play sand thats what i use a lot a work, i just filter it got a little piece of screen and i sift the sand before putting it in the reservoir
Old Apr 26, 2008 | 11:22 PM
Nick.Simonds
Ok good to know that i can use it.
Old Apr 26, 2008 | 11:44 PM
4reboy's Avatar
4reboy
I had the same sand blaster from harbor freight as well. You might want to upgrade all the valves to bigger ones because mine kept on clogging when the sand got too moist from all the compressed air.
but overall it was great, and I didn't use a respirator just the sand blasting mask that came with it, its fine.
Old Apr 26, 2008 | 11:57 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
but the most important thing is make sure to wear a respirator http://www.elitedentalservices.com/NIOSH.htm
Old Apr 27, 2008 | 12:21 AM
4reboy's Avatar
4reboy
ORIGINAL: rmodel65
well now i'm a little worried [&:] Not sure if my stuff had the crystalline silica or however its spelled.
Old Apr 27, 2008 | 12:24 AM
Adrenolin's Avatar
Adrenolin
rmodel65 is correct in the health issues and a respirator should be worn. This is also why I didn't just Sand Blast but decided to Wet Sand Blast and there is a huge difference. See this other thread which is also going on.
