The right compressor for the job?
http://www.harborfreight.com/cpi/cta...emnumber=92504
They have this at the Hf close to me on sale.
Would this be adequate for painting? Because, the next step up is like $800 and would kind of be expensive for a one time thing.
I have a 5hp, 30 gallon. It is good for spraying.Most air tools it's plenty. Running an airsander you wait awhile to let catch up. Sandblasting you need 5 times as much air, not bigger tank, but bigger compressor.
ORIGINAL: Nick.Simonds
I shouldnt be blasting much if any, so i should be good in that respect.
Cant wait to get working on the body.
Well if it goes well with mine. I have a line of friends that need new paint.
Is House of Kolors easy to use and straight forward stuff? Whenever I hear about paint they are usually mentioned.
That compressor should work pretty good. It will be too small for sandblasting, (need 10+ HP for this), and it might get slow when working with a D/A sander, D/As use a lot of air, especially when operated above recomended pressures like I alwaysdo...
It should work pretty well with a spray gun.
For the moneyI would consider making this purchase....I like that it is an oil type compressor...
220 volt, 60 Hz, 23.5 amps (start up), 12.5 amps (no load), 20 ft. stripped power cord ready for 220 volt plug connection;
