Torque vs. Horsepower
Old Apr 28, 2008 | 11:51 AM
racin66coupe's Avatar
racin66coupe
Default Torque vs. Horsepower
Which do you guys like more? im really thinkin torque right now
Old Apr 28, 2008 | 11:58 AM
Stepman's Avatar
Stepman
Default RE: Torque vs. Horsepower
I have to agree. Torque is what you feel and what makes the car move. HP means nothing to me.
Old Apr 28, 2008 | 12:05 PM
69thunder's Avatar
69thunder
Depends on what you want. Peak torque is lower in the rpm band and peak HP is higher. One analogy is torque in a quarter mile pass is like the 60 foot time and HP is the MPH at the end.
Old Apr 28, 2008 | 01:47 PM
JMD's Avatar
JMD
Torque and HP are inseparably linked...... choosing one or the other is like choosing Pepsi over Coke,,,, there is a "difference" but then again it is the same!
Note that torque and HP are always the same at 5250 RPM......
The real factor when considering torque and HP is where most, or maximum torque happens in the RPM band... As a rule, high torque low in the RPM band will come at the expense of maximum HP, but "drivability" will be better......
Generally high torque higher in the RPM band will result in higher peak HP, but at the expense of drivability...
The question is always answered with a compromise of some kind.....
Old Apr 28, 2008 | 02:35 PM
67mustang302's Avatar
67mustang302
ORIGINAL: JMD
You beat me to it.
In a way they're the same thing. Horsepower is just a way of measuring torque relative to engine rpm. You can't have one without the other. A broad torque band produces a broad power band. When you build a performance engine all you're really doing is shifting the torque curve around the rpm range, which changes how much horsepower is made and where.
http://www.epi-eng.com/piston_engine...and_torque.htm
That'll explain it pretty well.
Old Apr 28, 2008 | 02:36 PM
TexasAxMan's Avatar
TexasAxMan
JMD is correct. Although Inever noticed or knew that the two were the same at 5250 RPM, that's one I'll have to start watching out for.
Old Apr 28, 2008 | 02:41 PM
superdavid's Avatar
superdavid
HP=TqxRPM/5252
Torque is how much grunt your motor makes at low rpms.
Hp is torque at high rpms.
Old Apr 28, 2008 | 02:44 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
hp is how fast you torque happens
Old Apr 28, 2008 | 02:49 PM
67mustang302
This also talks about work and energy(essential to understanding horsepower and torque).
http://www.epi-eng.com/mechanical_en...y_and_work.htm
Old Apr 28, 2008 | 03:09 PM
Stepman's Avatar
Stepman
I haven't read any of those links but, you can make a 302 with as much HP as a 351, but it will never have the torque. Also, look at the trucks that only put out like 150 HP but have as much as 1200lbs of torque.
In other words...If people didn't like torque, they wouldn't be stroking 302's.
