dyno results today
Old May 1, 2008 | 08:55 PM
muggsy's Avatar
muggsy
Default dyno results today
Took my car and got it dyno tuned this week, got it back today. Final results after the tune were 300hp to the ground and just over 300 ft/lbs...torque curve looked nice. I spent some serious dough on a 347 last year about this time and also rebuilt the auto trans...I guess my Cobra intake is holding me back a bit and the guy said if I stepped up to an Edelbrock Air Gap I'd probably push about 330HP...is there really this much of an effect, and is it worth the swap? also, I have a stock 67 289 hood with the blinker option, would I run into any clearance issues?
Thanks!!!
[IMG]local://upfiles/26761/CED8B985505C4DAA94A213DB42A6B747.jpg[/IMG]
Old May 1, 2008 | 09:09 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: dyno results today
ORIGINAL: muggsy
Thanks!!!
I just put a 347 in my 85 gt and some told me I needed to run a single plain but I really don't have a cam for the r's a single plain is good to so I just transfered the rpm air gap from my 11 to 1 306 to the 347 and I have an xe 282 hr cam and just ran it 2 weeks ago and ran and 11.79 on 2 nd pass @ 117mph..........my guess is it has close to 375 to the rear wheels.....anyway the rpm is more than enoughdepending on what cam and heads you have??? 300 seems a little low for a 347 what are the cam and heads being used??
Old May 1, 2008 | 09:12 PM
mjr46's Avatar
mjr46
as for hood clearance with the rpm air gap..you should be fine I also have an air gap on my 66 with plenty of room left over
Old May 1, 2008 | 09:14 PM
Iskwezm's Avatar
Iskwezm
I dont think a intake will give you 30 hp.Might wanna look at the parts list
Old May 1, 2008 | 09:16 PM
muggsy's Avatar
muggsy
TFS twisted wedge Track Heat, CNC ported 185cc heads
TFS Stage 2 Cam (Crane grind) .542/.563
Forged internals
Cobra intake, Holley 600 carb w/ larger jets (I forget which size...maybe 82's??)
HeddmanTorque step ceramic headers, 2 1/4 in Magnaflow w/X pipe
open dif 3.55 8 inch rear
Griffin Alum Radiator
Mallory Unilite ignition
Old May 1, 2008 | 09:25 PM
mjr46's Avatar
mjr46
ORIGINAL: muggsy
Forged internals
heads and cam are decent sized and good choice..I'd change intake to the rpm air gap and a 650 double pumper..I'm runnind a 650 and it works well....also exhaust is a little on the small side..I'd of done 2 1/2 min...but none the less your set up looks decent
Old May 1, 2008 | 09:39 PM
1970coupe's Avatar
1970coupe
thats it? i would like you would be pushing around 350-375 with a 347. Isnt it a stroker? My best guess would be a better intake to boost a little more power. I would look into a good kit from wieand with a demon carb. That will make some good power.
Old May 1, 2008 | 09:43 PM
mjr46's Avatar
mjr46
also what type of dyno was it??? a mustang dyno?? or dyno jet??? also best gauge to see what power it makes is run it at the track and see the et vs mph
Old May 1, 2008 | 09:55 PM
ky's Avatar
ky
America ftw
ORIGINAL: 1970coupe
yeah its a stroked 302
Old May 1, 2008 | 10:13 PM
muggsy's Avatar
muggsy
it is a Ford racing 347 short block with the add ons I listed....The dyno was dynojet..
Yeah, the feedback from them was up the intake, the exhaust to 2 1/2 and think about the carb...
