thermostat recomendation/overheating
Old May 7, 2008 | 12:51 AM
bradleyb's Avatar
bradleyb
Default thermostat recomendation/overheating
I am finishing up my electrical replacement and Ron Francis recommends a 160 degree thermostat for carbuerated cars (180 degrees for fuel injection). I had read in a few threads here that the consensus seems to be 180 degree thermostat. Is this a concern because the there would be a greater temperature difference across the heads?
I am finishing up getting my 66 302running but it is overheating after running 5 minutes or so. I put a new 2 row aluminum radiator, new reverse flow water pump with the serpentine kit, 180 degree thermostat. I also run my c4 tranny lines to the radiator. I was thinking about running the car with the radiator cap off so I can see if the coolant moves at 180 degrees. The electric fan is giving me some struggle to get the probe to come on consistently at the right temperature - it is in the bottom above the lower hose. Could timing be an issue?I think I'll check the float levels, maybe it is getting lean after running a bit?
Any thoughts would be appreciated
Old May 7, 2008 | 01:59 AM
Stepman's Avatar
Stepman
Default RE: thermostat recomendation/overheating
I would run a 180 for carbs and 195 on injected. Reason being that computer cars are set to run at that and you will dump in more fuel at cooler temps. Also, it holds the coolant in the radiator a little longer to cool. I would put the probe near the top of the radiator, isn't it warmer up top?
Old May 7, 2008 | 02:39 AM
67mustang302's Avatar
67mustang302
I run 195 in mine. you should always run as hot as you can without compromising the tune or detonating. Hotter engine = hotter air/fuel charge = more rapid combustion = more power. The thermostat has nothing to do with overheating, unless it's stuck shut. It's a big issue on carb'd cars since cooler temps result in less fuel atomisation and you loose all your carburetion advantages. EFI will get stuck in open loop if it's too cold.
Old May 7, 2008 | 03:14 AM
Stepman's Avatar
Stepman
Not trying to argue but, I have to disagree with that. The thermostat does have something to do with overheating...but, I don't think so in this case. Also if higher temp = more power than, why the cold air induct?
Also, I thought the reverse pump was merely because of the serp belt, it drove it opposite to v-belt. Am I wrong on that?
Old May 7, 2008 | 11:14 AM
Starfury's Avatar
Starfury
The thermostat has zilch to do with overheating unless it's not opening or not flowing enough. I run a 195 high-flow and it works great. Temp sits at 200-215 depending on ambient air temp and driving conditions.
Cold air induction provides more dense air (cold air is more dense than hot air), allowing you to in turn provide more fuel, which then makes more power. The engine's temperature is what helps atomize the fuel as it makes its way down the intake runners. Better atomization makes more power.
Old May 7, 2008 | 12:36 PM
Stepman's Avatar
Stepman
Yeah, I thought of that after I slept and reread it. You're right. Long day, I guess.
Old May 7, 2008 | 12:47 PM
Gun Jam's Avatar
Gun Jam
-Brad
1) you need to move your temp probe to the top of the radiator it goes right under the hose on the top as that is the hot water exiting the engine and is equal to engine temp. The bottom of the radiator is cold water used to cool the engine.
2) if having your fan come on consistently as it should once 1 is fixed does not solve the problem then you are not running a big enough cooling fan or you are not running a shroud....the shroud directs air flow through the rad not around it.
what fan are you using and is your engine bored out?
How much HP are you producing?
-Gun
Old May 7, 2008 | 01:42 PM
bradleyb's Avatar
bradleyb
Thanks guys. Quick question on the temperature probe - if I have a reverse flow water pump, doesn't the coolant enter the bottom of the radiator and go up (that's why I put the probe at the bottom, which in hindsight, I am not sure makes sense - heat rises so the top of the radiator should be hotter but I was thinking in terms of where the coolant entered the radiator).
Gun Jam, I am not sure about the engine - I bought the car and the guy said the engine had been bored .040 over. The car had been sitting for several years and they said it was running great when it got parked. So instead of breaking into it, I just re-torqued the heads and put a Edelbrock intake/Barry Grant carb and thought I would give it a shot......once you start tearing into the motor, it is a slippery slope.
I wonder if the thermostat is working correctly, even though it is new, I think I will take the radiator cap off tonight and let it run to make sure it is flowing.
Old May 7, 2008 | 01:50 PM
bradleyb's Avatar
bradleyb
Also, can someone confirm that the direction of the coolant in a reverse flow system enters the radiator at the bottom?
Additional info - I have a psyclone electric fan - 2500 cfm (this seems pretty turbo, when it is running, it pumps some air). It does not have a shroud but it covers most of the radiator and of course is attached to the radiator.
I am wondering if I seated the distributor in correctly - I put in a Mallory HEI distributor and wonder if I have the teeth off? The car seems to sputter a bit if I push the accelerator quickly to floor, this could be float level too I reckon.
I have been working on this car and tore everything down to the shell and rebuilt it back up over the past 2 years. Now that we finally have it started, I am dying to get it on the road so this is really frustrating. The JBA header back exhaust sounds awesome and I can't wait to get this bad boy rolling
Old May 7, 2008 | 04:21 PM
67mustang302
Reverse flow water pumps still flow in the same direction(they're actually reverse rotation water pumps), coolant exits the top of the engine and enters the top of the radiator. Some newer engines have flow entering the top to cool the heads more effectively. On SBF's the reverse flow water pump has a "backwards" impellar in it, this means that it pumps effectively when the water pump is rotating in the opposite direction. This is for the late model setups that wind the serp belt around other accessories such that the back side of the belt runs the water pump, turning it in the opposite direction. If you have a reverse flow water pump and are turning it in the standard direction, that will cause overheating since the pump's impellar can't move the coolant properly.
