Replacing a door hinge
Old May 8, 2008 | 12:36 PM
AscolA's Avatar
AscolA
Default Replacing a door hinge
Hey Guys,
So my driver side door has some play to it. It shuts and lines up fine. When wide open I can lift up holding the handle, about an inch. The bottom hinge has seen better days, so I got a new replacement. I have the door supported and am planning on removing it from the car. When I removed two of the three bolts from the top hinge, I noticed that the backing/screw plate on the inside (behind the trim panel) of the door seemed like it was going to fall into the frame of the door.
So my question is this, can I safely remove all of the bolts without this happening? I hope this makes sense.
Thanks
Old May 8, 2008 | 12:56 PM
Stepman's Avatar
Stepman
Default RE: Replacing a door hinge
It's been a long time since I've done mine but, I believe that plate just kind of floats in there and will move around some. It shouldn't go any where though. If I remember right, it is that way to adjust the door.
Old May 8, 2008 | 10:02 PM
Kenny_Z's Avatar
Kenny_Z
Behind that plate is a series of metal catches that hold the plate in place. It won't fall in.
Old May 8, 2008 | 11:57 PM
valley firearms's Avatar
valley firearms
[align=left]mine did But I was able to fish them out by taking the kick panel off
ORIGINAL: Kenny_Z
[/align]
Old May 9, 2008 | 09:14 AM
AscolA's Avatar
AscolA
Mine didn't fall in. I got it all bolted up, however my door is now way off. It shuts, but there is a big gap at the back of the window. I kind of wish I just left it alone.
Old May 9, 2008 | 12:44 PM
davesanborn's Avatar
davesanborn
The reason those backing plates are looesly held into the structure of the A pillar is because this is how the door is adjusted to fit.
If the rear edge of your door glass isn't as it should be, loosen the A pillar door hinge bolts and slide the door back (or wherever it needs to be) until everything is lined up properly.
The gap around the door should be approx. 3/16ths of an inch.... the equivalant of the thickness of a paint stirring stick.
It's a PITA sometimes to get the door in the perfect spot, but if you play around with it long enough, you'll get it.
Good Luck,
Dave
Old May 9, 2008 | 09:50 PM
ky's Avatar
ky
America ftw
fitting panels and doors is hard. im not really looking forward to it on mine
5.0muscle
Jan 11, 2016 01:17 PM
Art161
Sep 9, 2015 10:33 AM
Doogie65
Sep 6, 2015 02:55 PM
cbird1177711
Sep 3, 2015 08:43 PM
SYNY5TER
Sep 2, 2015 01:35 AM
