My heater core grenaded
Old May 8, 2008 | 11:12 PM
valley firearms's Avatar
valley firearms
Default My heater core grenaded
[align=left]I took her out for a drive today. I was on the way to my buddies place where my gears will be changed tomorrow to 3.55's and my heater core went. It happened when I jumped on it. Here I am tring to keep her straight and wondering what the heck was going on. Then the steam started and I though, Holly crap I'm on fire! I quickly realized it was only steam. Here is the video of when it happened. You can't see it happen but I'm sure you will enjoy it anyway Turn the volume up, it's better that way!
http://www.youtube.com/watch?v=dZqHe7oxkng
I have never replaced a heater core. Can someone give me a quick run down. Thanks guys!
[/align]
Old May 9, 2008 | 01:20 AM
Starfury's Avatar
Starfury
Default RE: My heater core grenaded
Are you running the factory restrictor elbow on the manifold, or just a cheapo open piece? The factory pieces have both a tube that extends into the coolant stream to keep from sucking up air, and a restrictor built into the elbow that keeps the engine from trying to push too much coolant through the heater core.
Edit:
PS: The factory shop manual has all the instructions you'll ever need
Old May 9, 2008 | 02:33 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah too much fluid is a problem with the 5.0 guys, also another common problem is old fluid. the fluid can actually become acidic basically functioning as a battery its a good idea to change fluid at the recommended intervals. and also to only use distilled water (no minerals etc) tp water only speeds the devastation
Old May 9, 2008 | 05:24 AM
ThanksDad's Avatar
ThanksDad
http://www.mustangmonthly.com/projec...ild/index.html
I'm not sure what year your car is but try this site.
Old May 9, 2008 | 08:43 PM
valley firearms
[align=left]No, I am not running a restrictor. I had to use a 45 degree fitting due to the weiand. I will add one in line now that you suggested that. It never even crossed my mind about the psi. Thanks for the info
ORIGINAL: Starfury
[/align]
Edit:
Old May 9, 2008 | 09:01 PM
Starfury's Avatar
Starfury
Call Glazier's, they sell a longer factory elbow.I got mine from them
Old May 9, 2008 | 09:32 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
what to get a clena looking heater install, go to the junkyard and buy the water tube off of the intake manifold. it will get rid of the 1and and 1/2 of hose from the intake to the firewall
Old May 9, 2008 | 09:34 PM
ky's Avatar
ky
America ftw
hmm i was wondering why the elbows had the long tube on them. of course, the originals are pretty much corroded away.
but i have a brand new heater core, so would i need to worry about it being affected by the psi since i dont hve a long elbow?
Old May 9, 2008 | 09:37 PM
Starfury's Avatar
Starfury
Yes, especially if you spend time at higher rpm's, or if you have a high-volume water pump. That restrictor was there from the factory for a reason.
Old May 9, 2008 | 09:42 PM
ky's Avatar
ky
America ftw
ill probably modify my elbow i bought. i can weld an extension onto it. i bought like 4 different elbows and i finally found one i liked/that fit well.
