c4
Old May 9, 2008 | 10:36 PM
anderson sc's Avatar
anderson sc
Default c4
need a c4 for a 67- v8, want to rebuild it my self. Was there any diferance if so what to look for? About how much should I spend for one that will need rebuild? Thank you!
Old May 9, 2008 | 10:41 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: c4
a core maybe 50-100 $ the rebuild is pretty easy it doens trequire any expensive tools, i used a tci kit and bought a new stall converter to go with the last one i rebuilt
Old May 9, 2008 | 10:44 PM
anderson sc
Default RE: c4
I have rebuild trannys before but never had to find one, is there anything I should look for (type of bell housing) so on?
Old May 9, 2008 | 11:57 PM
67coupe's Avatar
67coupe
Default RE: c4
As long as it is a 6-bolt bellhousing you should be good. They did change the splines on the converter lmid 70's I think, butas long as you have the converter for the trans you buy youshould be good.
Old May 10, 2008 | 09:53 PM
anderson sc
Default RE: c4
THANK YOU FOR THE INFOR. WHENWAS THE C4 STOPED BEING MADE. WOULD A NEWER TRANNY WORK? THE ONLY FORD TRANY I REBUILD WAS A A4LD. SO I DONT KNOW MUCH ABOUT FORD TRANS. KEEP IN MINE THIS CAR IS GOING TO MY WIFES DAILY DRIVER ,NO HOT ROD STUFF.
Old May 10, 2008 | 11:02 PM
tyler72's Avatar
tyler72
Default RE: c4
65-69 is pan fill 24 spline. 70 and up is case fill 26 spline. Obviously, the more splines the stronger and more reliable it is, so look for a C4 with the dipstick in the case, not the pan. Also, the parts for these are cheaper as well.
Old May 10, 2008 | 11:22 PM
ky's Avatar
ky
America ftw
Default RE: c4
STOP YELLING. NO NEED FOR CAPS.
[8D]
Old May 10, 2008 | 11:26 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: c4
BUT I LIKE ALL CAPS
Old May 10, 2008 | 11:50 PM
ky's Avatar
ky
America ftw
Default RE: c4
ILIKETYPINGWITHNOSPACES.
Old May 11, 2008 | 07:40 AM
anderson sc
Default RE: c4
thank you very much!
