Rusted Floor Panel Question
Old May 11, 2008 | 05:22 PM
myblackbeauty's Avatar
myblackbeauty
Default Rusted Floor Panel Question
Is there a way to check whether or not the floor panels are rusted out. There isn't a leak coming from the cowel so I think I'm on good ground. So, without taking up the carpet, is there a way to check if the floor panels are rusted? Also, anyone know why trunks are a common place for rust in classic mustangs?
Old May 11, 2008 | 05:39 PM
Tony R's Avatar
Tony R
Default RE: Rusted Floor Panel Question
climb under the car and you will see if it is rusty. Take a screwdriver and poke around the pan. If you go through easily you are rusted through.
Old May 11, 2008 | 07:53 PM
HGC's Avatar
HGC
It's not just cowl leaks. My toeboards had rust (still do) which probably started from the outside where rocks would be thrown up and chip the undercoating. That actually can happen with any car. I've seen it on a Buick and a Chevy.
Old May 11, 2008 | 07:55 PM
ky's Avatar
ky
America ftw
pulling back the carpet is a no-brainer. doesnt take long to do[&:]
Old May 11, 2008 | 09:01 PM
vineman's Avatar
vineman
you could also press downhard on the floor itself and listen for it crackling maybe? or to see if you can go through.
mtgldr
Feb 3, 2024 09:00 PM
GPR
Dec 16, 2015 12:21 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Sep 17, 2015 07:57 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
