problems with c4
Old May 12, 2008 | 11:01 PM
DenDen's Avatar
DenDen
Default problems with c4
My 1st gear band seems to be slipping.When I manually downshift into 1st,it seems like its in neutral.When I hit the gas,it goes.It seems normal in drive but I have had it downshift into 1st and slips a bit.
Do I need to adjust 1st gear?How do I do that?
fluid level is good,no sign of burned oil.
Had it rebuilt 5 yrs ago.
Old May 13, 2008 | 01:14 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: problems with c4
you are checking the fluid with the car running right? i have to ask
Old May 13, 2008 | 01:28 AM
DenDen's Avatar
DenDen
yes
Old May 13, 2008 | 07:31 AM
imnotmy77stang's Avatar
imnotmy77stang
there is a procedure for tightening / adjusting the bands but i'll be damned if ican remember the details
Old May 13, 2008 | 08:36 AM
65Coupester's Avatar
65Coupester
Adjusting the bands on a C4 is pretty easy.
On the low/reverse band you use the set screw on the right side of the tranny, just above the vacuum modulator.
Put a wrench on the screw and an box end wrench on the jam nut. Loosen the jam nut without turning the screw.
Now torque the screw down to 10 foot/lbs torque, which is just snug-not tight. Now back off 3 turns. Keep the screw from turning and tighten the jam nut. Thats it.
If you are not confident making the adjustment then just keep track of how many turns it took to tightnen the screw so you can put it back if you are not sure. Don't over torque the screw. Use a sharpie to mark the screw or put a scratch on it to keep track of the turns. Work slow.
Old May 14, 2008 | 08:42 PM
hutchamatic's Avatar
hutchamatic
Acutally, Your trans is working correct. If it was slipping you would be slipping in reverse also. The band is additional holding power in 1st. When downshifted into 1st while moving without any throttle it will apper as if it is in neutral. The one way clutch in the rear is overrunning at this point until you accelerate.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
