1967 Coupe newbie, needs help
Old May 18, 2008 | 08:05 PM
kojo2001's Avatar
kojo2001
Default 1967 Coupe newbie, needs help
Hi,
I just purchased a 1967 coupe. The car is in pretty good shape. The brakes seemed to be ok on the 1st day I drove the carbut yesterday the brakes seemed tonot beengaging all the way. When you pump the brakesa couple of times it seems to get a little better but stillscary. The front brakesare disc if that helps at all and per prior owner, the master cylinder was replaced about 2 years ago. I am goingto bring it to a random brake place tomorrow but wanted to get anidea of what I am in for. Does any one know a good reasonable mechanic in the San Fernando Valley, Ca area?
Thanks,
Justin
Old May 18, 2008 | 08:10 PM
racin66coupe's Avatar
racin66coupe
Default RE: 1967 Coupe newbie, needs help
it almost seems like they need to be bled well. also, when the master cylender was replaced it may not have been bled id try that as well as all 4 corners
Old May 18, 2008 | 08:40 PM
ky's Avatar
ky
America ftw
bleed the brakes. start as far away from the master cylinder as you can. which means passenger rear wheel first. then driver side. then pass front. then driver front.
Old May 18, 2008 | 08:48 PM
Mustangdemon67's Avatar
Mustangdemon67
possibly vacuum leak on the booster. are you loosing brake fluid but its not leaking?
Old May 18, 2008 | 08:53 PM
40overmustang's Avatar
40overmustang
does it have disc or drums in the front?
1slow67's Avatar
1slow67
ROTM Moderator
ORIGINAL: Mustangdemon67
He might not have checked to see if it had fluid. Did you?
Old May 18, 2008 | 08:56 PM
kojo2001's Avatar
kojo2001
I dont see any leakage, But I did maybe hear almost like a little bit of a air sound when pushing pedal ( not very mechanical so please excuse weird description)
Justin
Old May 18, 2008 | 08:58 PM
kojo2001's Avatar
kojo2001
It has disk in front
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
uberstang1
Sep 20, 2015 06:42 PM
Sep 17, 2015 07:32 PM
