c4 gaskets
Old May 21, 2008 | 08:13 PM
slick63's Avatar
slick63
Default c4 gaskets
I am planning to drop the pan on my C4 transmission and change the fluid, pan gasket and filter. Also, I believe I see some fluid leaking where the shifter comes in.
I would like to have a set of gaskets/seals on hand when I start this operation. Not only for the shifter, but other gaskets/sealsthat are likely to need replacement, so that I can hit them all at once.
If anyone can recommend a reasonable shopping list, I'd appreciate it. Thanks!
Old May 21, 2008 | 08:41 PM
65rangoon's Avatar
65rangoon
Default RE: c4 gaskets
not sure, i know i have an output shaft seal & tranny kit for mine sittin at my parents house waitin for me to change it out next weekend. not sure if ill make it to the OSS
Old May 23, 2008 | 08:11 PM
hutchamatic's Avatar
hutchamatic
You can buy a complete reseal kit for around $35-$45.
Old May 24, 2008 | 02:18 AM
Stepman's Avatar
Stepman
Just look to see what is leaking, really. The pan and shifter are the two big ones. I believe you have to remove the pan to do that shifter, it should be an o-ring.
Old Jun 3, 2008 | 03:50 PM
slick63's Avatar
slick63
Thanks for the tips!
Old Jun 3, 2008 | 03:58 PM
TripleHmotosports's Avatar
TripleHmotosports
I believe you have to drop the valve body to replace the shifter seal.
Oct 26, 2015 05:01 PM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
Demodulates
Sep 18, 2015 11:14 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
