Modern V6
Old May 23, 2008 | 05:01 PM
adam_tj's Avatar
adam_tj
Default Modern V6
How difficult would it be to swap a 4.0L V6 from the current stang into a '67? I know I'd likely have to fabricate engine mounts, wiring, etc. Has anyone ever seen this done?
Old May 23, 2008 | 06:21 PM
ky's Avatar
ky
America ftw
Default RE: Modern V6
sounds interesting. theres a build on here about a 66? with a turbo 4 cyl. pretty cool actually.
Old May 23, 2008 | 06:24 PM
1970coupe's Avatar
1970coupe
not worth the trouble. Just buy a new mustang v6
Old May 23, 2008 | 06:31 PM
tyler72's Avatar
tyler72
why would you want to do that??? a V6 in a classic is way not cool in my opinion. Dont choose the 4.0 OHC motor out of a late model stang (or explorer, or ranger; they are the same engine) because they have major timing chain problems. There are a total of 3 timing chains; one runs from the crank to a dummy shaft (where a regular cam would be), one runs from that dummy shaft to one cam in front of the engine, and the last one runs from the dummy shaft to the other cam in the BACK of the engine. So guess what. When the timing chain tensioners break and go bad (and beleive me they will), you will have to pull the engine back out to fix them. Oh, and they dont have any keyways or anything, the gears are all "clamped" into place by just tightening the bolt. It takes special tools to time one, and they cost $400 for the set, if you do all of the labor yourself. Like I said, Im not one for V6 stangs, but if you do it, dont use a 4.0 SOHC. I would reccommend a supercharged 3.8 out of an early 90s Thunderbird supercoupe. They make awesome power in stock form, and are faily easy to come by for a very reasonable price. Just my 2 cents worth.
Old May 23, 2008 | 06:53 PM
67mustang302's Avatar
67mustang302
If you really want to, I'd wait for Ford to release their TTGI V6.
Diode Dynamics
28
May 26, 2022 12:02 PM
carid
Jul 8, 2016 09:55 AM
Mr. D
Sep 12, 2015 04:43 AM
