Fuel filters are a must
Old May 25, 2008 | 05:23 PM
groho's Avatar
groho
Default Fuel filters are a must
Just got finished spending the last day and a half cleaning out my carb because of a crappy fuel filter. Took it out for a spin on friday, hit 2nd, about to hit third and then a sudden loss of power. Felt like I was running at 80% and it would barely idle. Got it home thinking i had a vacuum leak, sprayed down the manifold and carb, nothing. Tight as a fish's backside. Then I noticed as a moved the idle adj screw, nothing happened. Darn primary and idle circuit clogged. Pulled the carb, opened the topand noticed rust in the bottom of the carb.I was running a fuel filter, but it was one of those cheap units. Not any more. This goes to prove you need to run a good fuel filter! What amazed me the most. . . the symptoms was almost identical to a vacuum leak.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
