Clutch location
Old May 25, 2008 | 09:54 PM
Tony R's Avatar
Tony R
Default Clutch location
I am looking for a pic of a hydraulic clutch in the bay of a 65. I am doing a conversion from an auto and am in the process of finishing my bay and want to make sure that I still have the hole for it. I went a little crazy welding holes shut to smooth out the bay and I may have filled it in.
thanks
Tony
Old May 25, 2008 | 10:06 PM
JamesW's Avatar
JamesW
Default RE: Clutch location
http://midnightdsigns.com/Mustang/HYD%20Clutch.htm
Old May 26, 2008 | 06:53 PM
Tony R's Avatar
Tony R
thanks james. i have the big hole but I dont have the bolt holes.
Old May 26, 2008 | 07:24 PM
JamesW's Avatar
JamesW
You have to add the holes, they're not there originally
Old May 26, 2008 | 07:49 PM
Adrenolin's Avatar
Adrenolin
There are knockouts in the 67 however none of them will work if you have a power break booster installed. If your going with power breaks then you'll have to drop it down further drilling new holes. Likely have the same issues on the 65. Weld them all shut and then locate where the hole needs to be and drill it out to fit.
Old May 26, 2008 | 08:37 PM
Tony R's Avatar
Tony R
I have power brakes. How much lower does the hole have to be? I haven't found a pedal assembly yet or purchased any of the components for the clutch to mock it up.
Old May 26, 2008 | 11:11 PM
Adrenolin's Avatar
Adrenolin
Low enough that I've been told by a few people here that I cant do a hydraulic clutch setup on our 67 due to the size of the power booster.
Anyways.. Car is currently stripped down and I put the break/clutch assembly in and pushed the break booster through the firewall. They are correct in that a Clutch Master Cylinder wouldn't fit in the stock (or available knockout holes). That said, if I modify the connecting point location on the clutch pedal it should fit fine. Took a few measurements and as long as the clutch master cylinder has a separate fluid reservoir it'll work.
Old May 27, 2008 | 01:30 AM
67mustang302's Avatar
67mustang302
I'm running hydraulic on my 67, no power brakes though. Mounted the m/c basically right on the hole for the mechanical linkage, and built a reenforcing plate. It's pretty tight with the Wilwood master cylinder for the clutch tucked up in that corner, but it's doable. I imagine it would be VERY difficult to fit with a power booster though.
Old May 27, 2008 | 09:54 PM
Tony R's Avatar
Tony R
how much difference is there between a 65 and a 67 though. I will just live with it the way it is unless someone says different about the 65 location. When I get my clutch I will fit it and if it has to be moved it is only a little bit of paint that I will have to redo. I will have to paint my flames on my firewall at a later date when I get the rest of the car done anyways.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
stangin1996gt
Sep 21, 2015 11:01 AM
