transmission question
Old May 26, 2008 | 11:15 PM
SJs 66coupe's Avatar
SJs 66coupe
Default transmission question
I am trying to figure out if my '66 has a three speed or a 4 speed.
My guess is that it is a three speed, know from the data plate that is what it came out of the factory with.
However, is there some way to look at the transmission or otherwise tell what the transmission is?
I only ask because I need to order the backup lights switch and apparently it is a different switch for a 3 verses a 4 speed.
Old May 26, 2008 | 11:16 PM
Gun Jam's Avatar
Gun Jam
Default RE: transmission question
is it an auto or manual trans?
Old May 26, 2008 | 11:18 PM
SJs 66coupe
Automatic even though I sort of wish it was a manual.
Old May 26, 2008 | 11:20 PM
Gun Jam's Avatar
Gun Jam
does it have a green dot on the shift selector next to drive?
Old May 26, 2008 | 11:22 PM
SJs 66coupe
Honestly, I don't know that I have ever looked. Will look next time I am out in the garage.
Does the green dot indicate one type of transmission verse the other?
Old May 26, 2008 | 11:27 PM
Gun Jam's Avatar
Gun Jam
you probably have a C4 three speed auto.
the green dots as far as I know are a dead giveaway of the c4.....Further more unless someone swapped it out for an AOD I dont think they ever came with 4 speed autos in a 66 I dont think there was such a thing...i might be wrong but i doubt it.
-Gun
Old May 26, 2008 | 11:29 PM
Gun Jam's Avatar
Gun Jam
the c4 shift pattern is park Rev N, drive 2nd 1st........If you have that patten i would bet quite a bit on it being the c4 3 speed
Old May 26, 2008 | 11:33 PM
SJs 66coupe
I have some paper work where the previous owner had it rebuilt some years ago, as far as I know it is the same type of transmission that came in it out of the factory. It may / may not be the original factory tranmission, not sure.
However, the previous owners were real big on keeping it as much as possible just like it came out of the factory so my guess is they either rebuilt it or replaced it with exactly what was in there.
Old May 26, 2008 | 11:36 PM
ky's Avatar
ky
America ftw
i though it was
PARK
REVERSE
NUETRAL
RAIN (start in 2nd, then shifts to 3rd)
DRIVE (1st, 2nd, then 3rd)
1st (if you shift into this at above ~25 mph it wont shift down to first until you slow to below about 25mph.)
Old May 26, 2008 | 11:37 PM
ky's Avatar
ky
America ftw
i know it is for my dads. and thats how the stock 66 shifter is.
although my tranny went
park
reverse
nuetral
drive
2nd only
1st only
