Correct Hedder for 347 engine- 302 vs 351
Hi All,
I am planning to put a Smeding 347 in my 65 coupe later this year. My rack & pinion manufacturer recommended Headman hedders. My question is, do I need to go with hedders for a 302 or hedders for a 351? The 347 engine uses a 302 block. However, are the heads taller on a 347?
Thanks!
Thanks!
My 347 is a 5,0 stroker.
You can run stock cast 289 manifolds if you wanted too.
Tri Y is naice if you know they will fit.
I have the MAC shrt ones on my engine due to diff in the front suspension and a TKO.
bradleyb
Nov 27, 2015 07:50 PM
jaiidutch
Sep 14, 2015 10:29 AM
