Rough Idle 200 I6
Old Apr 28, 2005 | 08:26 PM
MrMootsie's Avatar
MrMootsie
Default Rough Idle 200 I6
More newb questions. At idle, this engine sounds rough to me, and there is a bit of black residue on the ground when it runs. This goes away after it warms a bit. Any ideas?
also, is there some non-rocket scientist way to figure out if it timed correctly?
cheers,
MrM
Old Apr 29, 2005 | 05:02 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Rough Idle 200 I6
If it smooths out after it has been running for awhile, your choke is probably closing too much, then after it opens it smooths out. To time it right, you will need a timing light, and you will need to know the degrees below TDC to tune it to. I believe for the 200 CID that would be 10 degrees Below Top Dead Center. Then loosen your distributor and while the light is hooked up to #1 cylinder and the battery, shine the light on the marks and turn the dizzy until the two lines line up. The pointer is on the timing cover, and the line is on the harmonic balancer. Marking the lines with either white out or white chalk helps you see it better. Then turn off the engine and tighten the dizzy down.
Or, you could tune it by ear, but that will only get you close.
Old Apr 29, 2005 | 09:39 AM
MrMootsie's Avatar
MrMootsie
I'll give it a shot.
Old Apr 29, 2005 | 02:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Just another thought. Do you have a manual or automatic choke? If it is manual, just don't pull it out to fully closed. If it is automatic, then you need to adjust the butterfly by loosening the choke housing, and turn it to the right two or so notches, then tighten it back down.
On edit: That is an assumption that the spring in the choke housing is not burned, and that it is still doing its' job by opening the butterfly gradually as the engine warms up. Make sure you have heat from the header to the choke housing.
Old Apr 29, 2005 | 03:28 PM
MrMootsie's Avatar
MrMootsie
Must be auto, as there isn't a choke **** like there was on my first gen RX-7.
Old Apr 29, 2005 | 03:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Then try to adjust the choke housing so that the butterfly doesn't close quite so much at cold idle. Automatic chokes on these old carbs have to be adjusted to the climatic conditions of where you live. Warm climatic conditions require less butterfly choke on initial start-up than cold climatic conditions. That is why you have to adjust the choke housing to meet the conditons of where you live. And, they have to be adjusted seasonally. Welcome to the world of vintange Mustang wrenching.
Old Apr 29, 2005 | 05:46 PM
MrMootsie's Avatar
MrMootsie
great.....[8D]
thanks for the info!
Old Apr 29, 2005 | 11:23 PM
MrMootsie's Avatar
MrMootsie
this is what it looks like right now.
[IMG]local://upfiles/16168/0F68E48108CE4499B7A168244D2677D3.jpg[/IMG]
[IMG]local://upfiles/16168/8920D72F6B5849028E64E59450A49294.jpg[/IMG]
[IMG]local://upfiles/16168/ECDDC1D352564E2983D1C7C5523FA77E.jpg[/IMG]
Old Apr 30, 2005 | 06:16 AM
Soaring's Avatar
Soaring
I ♥ Acer
Wow! Very nice. Now, dump the dice on the rear view mirror. [:'(]
Hey, I don't see a picture of your vert in the gallery. Send a pic to Amanda@mustangforums.com and she will add it to the gallery.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
