Starting problem
Old Jun 15, 2008 | 02:09 PM
cfd2bc's Avatar
cfd2bc
Default Starting problem
I fired my new engine up the other day and did the 20 minute break in. I had to jump the solinoid to do it. It won't start with the key. I have the neut safety switch hooked up and have made sure the linkage has the gear selector all the way back in park. Is there a way to bypass to see if it is the neut switch?
Jeff
Old Jun 15, 2008 | 04:35 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Starting problem
in the crank position see if you got current on the small wire to selonoid if you do ..nuetral saftey is fine if not.. could be ignition switch or nuetral saftey..from there you'd have to test switch.....
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
