hmm block years?
Old Jun 17, 2008 | 09:56 PM
SalikDDD's Avatar
SalikDDD
Default hmm block years?
ok.. i know this is everywhere but for some reason my dumbass self cannot find it..
what year did they switch the 302 to a roller block? i need to get a non roller short block :| was it 68-84?? or ?
Old Jun 17, 2008 | 10:09 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: hmm block years?
i believe it was 85 on H.O. blocks
Old Jun 17, 2008 | 10:11 PM
SalikDDD's Avatar
SalikDDD
ahh good good. so my suspicion was correct. now.. converting to a roller block.. if i got a roller long block, and wanted more bump i just swap the cam, bolt everything back on and switch the firing order correct?
Old Jun 17, 2008 | 10:16 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you follow the firing order of the cam your using the 351(5.0 h.o.) firing order cams will make more power and run smoother
Old Jun 18, 2008 | 05:16 AM
SalikDDD's Avatar
SalikDDD
hmm.. guess it's easy enough. roller cam time and a new short block i guess.
Old Jun 18, 2008 | 10:37 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if your getting a new short block why not get a roller one? its cheaper to buy a roller cam for
Old Jun 18, 2008 | 04:58 PM
SalikDDD's Avatar
SalikDDD
i probably will, since i got roller lifters etc, i might as well just complete the roller lineup. guess i'll need new pushrods now but hey whatev. at least everything transfers from my 289 to it.
Old Jun 18, 2008 | 05:51 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i wanna build a roller 289 just machine the lip off the crank so you can use the 1 piece rear main seal
67LimeCoupe
Sep 30, 2015 04:46 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Sep 8, 2015 05:21 PM
Sep 8, 2015 11:50 AM
