Flex fan spacer
Old Jun 18, 2008 | 08:35 PM
Green69's Avatar
Green69
Default Flex fan spacer
Just picked up a flex fan to replace my original four blade fan, hoping to cool things down in traffic. Thing is, which is more important, the distance from the radiator or how deep it sits in the shroud. The fan manufacturer says best efficiency is with the blade around 1" from the radiator. However, they also state that the fan should be half in/out of the shroud. Well, I can't do both. Either it sits deep in the shroud, or it sits over two inches from the radiator. If I want the fan half in/out of the shroud, I would need a 2 1/2" spacer. I probably should email the manufacturer, but thought I'd throw it up here anyway. Any suggestions? Thanks.
Old Jun 18, 2008 | 08:51 PM
my77stang's Avatar
my77stang
Default RE: Flex fan spacer
i dont think its going to make that much of a difference honestly. as long as whichever way you end up installing it the blades arent completely out of the shroud i would think you should be ok.
Old Jun 18, 2008 | 09:07 PM
7tMach's Avatar
7tMach
It did make a difference in my Cougar. It was inside the shroud close to the radiator, Ran hot, real hot. Read on a website that the blades should be half in and half out of the shroud. We cut the spacer, mounted it, FIXED. We had replaced thermostat, water pump, and radiator. All along, it the fan to shroud realtionship. Half in half out.
Old Jun 18, 2008 | 10:50 PM
Starfury's Avatar
Starfury
Exactly, you want the fan half in and half out of the shroud for optimal efficiency. Too close to the radiator and it screws up airflow.
Old Jun 18, 2008 | 11:06 PM
Green69's Avatar
Green69
Thanks, that was the advice I was looking for. I now need a 2 1/2" spacer... anyone have one laying around?
Old Jun 18, 2008 | 11:11 PM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
Actually I am almost 100% positive i DO have a nice one laying around... was too close for my current setup so i replaced with a shorter one. PM me your contact info and ill call you tomorrow when I can get to my storage unit and measure it. I'd give it to u for $5 plus postage.
PM me your number, etc.
mtgldr
Feb 3, 2024 09:00 PM
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
UrS4
Oct 3, 2015 06:23 AM
Sep 25, 2015 09:06 AM
