Vin Numbers/Vin tag
Old Jun 21, 2008 | 06:38 PM
sixtysix's Avatar
sixtysix
Default Vin Numbers/Vin tag
I have a 66 convertible-The vin is stamped on the left side top inner fender apron as usual.Over top that is a deckled VIN tag screwed down in place.I m sure this doesnt belong there...where is the correct place for this VIN tag?
Thanks Scott
Old Jun 21, 2008 | 06:40 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: Vin Numbers/Vin tag
Let me go get a picture of mine.
Old Jun 21, 2008 | 06:44 PM
1slow67's Avatar
1slow67
ROTM Moderator
Here is where mine is on my 67.
[IMG]local://upfiles/69894/4D8D5FE137EB4C6E8F82383605ACE166.jpg[/IMG]
[IMG]local://upfiles/69894/05A277135C1C4E9FB7A84594B2E8EA29.jpg[/IMG]
Old Jun 21, 2008 | 07:45 PM
sixtysix's Avatar
sixtysix
Thanks so much for the pixs-I will see if there is a small hole around the hinge area for the screw Thanks again Scott
Old Jun 22, 2008 | 09:59 AM
davesanborn's Avatar
davesanborn
Scott,
The piece you're referring to is called the "body buck tag". It was used at the factory as the car rolled down the line to help the Ford workers assemble the car with the correct options. It was never intended to be a permanent part of the finished car. Some factories used the buck tag system, some didn't. Some left the tags on after the car was finished, some didn't. The buck tag was loosely installed onto the fender apron (or radiator support... or cowl area). If it's located in an odd position, that's probably where it was originally installed (loosely attached with an odd looking screw). Rarely would an owner take the time to relocate the body buck tag, so my guess is that it's in the position where it was originally installed.
Dave
Old Jun 22, 2008 | 01:32 PM
sixtysix's Avatar
sixtysix
Thanks dave-I found no hole near the hinge,soI will put it back over the vin that is stamped into the fender apron.It does have that odd screw too.....Thanks Scott
Gabe_mlcc
Sep 7, 2015 11:56 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
Aug 10, 2015 11:46 AM
