Tire Size Help
Old Jun 25, 2008 | 07:07 AM
UBY289's Avatar
UBY289
Default Tire Size Help
I am thinking on getting a set of Torq Thrust D 15x7 with 235 60 15 T/A tires for my 67 Coupe . Can anyone see any trouble with these not working. Or does anybody run these size of tires that they can post a pix of ,thanks.
Old Jun 25, 2008 | 11:57 AM
UBY289's Avatar
UBY289
Default RE: Tire Size Help
Can anyone help
Old Jun 25, 2008 | 12:09 PM
1slow67's Avatar
1slow67
ROTM Moderator
I don't think those will have any problems. I run 245/50R16s in the rear. So I think those will work. So I know you can use up to 245. My rims are 16x7, just 1 inch bigger than yours.
Old Jun 25, 2008 | 01:58 PM
blue66mustang's Avatar
blue66mustang
I have the same wheel and tire on the rear of my 66. No problems.
Old Jun 25, 2008 | 06:12 PM
Aussie66Fastback's Avatar
Aussie66Fastback
235 is on the upper end of what i would put on a 7" rim and 245 is 8" terrtitory.
i have 225/60/15s on 15x7 ttds had some rubbing issues on the front of my 66 but might be ok on a 67. the issue is the backspacing is only 3.75". what that means is that it is pushing the outer edge of the rim closer to the wheel arch compared to, say,a mag500 in the same wheelwhich has4.125" bs. Makes a big difference. rub or not rub will also depend a little on your ride height and spring rates at the front as well.
Not an issue for the rears.
have you looked at dodgestangs chart?
btw,ttds do look very cool on a mustang! I dont think you would regret the choice.
but i would also ask the following questions...
1) manual or power steer?
2) would you run a different size front and rear?
if manual steer i would tend to stick to the 225s on the front and if you were prepared to go 2 different rim sizes, i would consider 8" with 245s for the rear to fill out those big fenders.
Old Jun 25, 2008 | 06:22 PM
1slow67's Avatar
1slow67
ROTM Moderator
Depending if your car is lowered they will work. My 67 is lowered and I put the 16s on. It didn't change my ride height at all. I have banged up my front fenders pretty bad and the rear tires get cut into when I hit bad bumps. You might have this problem, but I guess it depends on your car. I would recommend rolling fenders if you have this problem. I still have to do mine.
Old Jun 26, 2008 | 07:31 AM
UBY289's Avatar
UBY289
I have manual steering . New leafs in the back the front looks alright . I might go withwhat you suggested with a smallerfront and larger back . I will check this out and let you know what I do , where do I find this chart,thanks all for your input.
Old Jun 26, 2008 | 08:24 PM
Aussie66Fastback
the chart used to be in the FAQ.
try http://www.dodgestang.com/index.html
Old Jun 27, 2008 | 12:19 AM
MonsterB's Avatar
MonsterB
i would go with the torque thrust M's in a 17x9.
here is a link to them on my car. take in mind that the car doesnt have the engine in in these pics
http://s304.photobucket.com/albums/n...onsterpoolboy/
2007CalSpec
Sep 9, 2015 05:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
M3hunter
Sep 5, 2015 03:42 PM
