Tires
Old Jun 25, 2008 | 06:25 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Tires
I was wanting to know if these tires are safe to run on my 16x7s. I know my fronts are, but I am unsure about the rears. The rears are 245/50R16. While my fronts are 205/60R16.
Old Jun 26, 2008 | 08:22 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: Tires
seeing as i sowed that doubt in your mind, i thouight i better start digging. my tire guy said no...get a minimum 8" rim. It wasnt as easy to find a straight answer on the net but here's a couple of refs. the first one is worth reading from the start for overall tire info. the rim width calc is about 1/3 the way down page 2.
http://www.carbibles.com/tyre_bible_pg2.html
http://www.simextyres.co.nz/downloads/Car%20tyre%20conversion%20chart.PDF
I tried it for your tyres and the calc (with his disclaimer to check at a reputable tire shop) says you can put a 245 on a 7" rim. I would have thought its way too wide a tire. It will give you a lot of bulge and make the tyre appear narrower.
me...I wouldnt do it. I think it will handle like crap on the rear. Just to give yourself a better visual, try measure 7" ona ruler against a pinch under 10" which is your tyre width.
the game has changed a bit with larger rims and lower profile tires too. good luck hope this is some use to you
Old Jun 26, 2008 | 10:18 PM
redstallion's Avatar
redstallion
Default RE: Tires
i agree you should run a wider wheel. I run 235's on a 17x8 and wouldn't go narrower
Old Jun 26, 2008 | 10:41 PM
65rangoon's Avatar
65rangoon
Default RE: Tires
those 245s would be 9.65" ... on a 7" wheel.
Old Jun 27, 2008 | 12:22 AM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: Tires
Yeah they bulge out. I can't find any 235/50R16s. Only 245s and 225s. I don't want to go down to 225s though.
EDIT: How big of a difference in width is 225 from 205? I don't want to have the same size tires all around. I want smaller in the front like right now.
Old Jun 27, 2008 | 02:47 AM
Aussie66Fastback
Default RE: Tires
225's will be noticeably bigger than the 205's on the same rim, but if you really want that drag look, you'd need a bigger rear rim to take advantage of the 245s
alternately look for a 235 in a different aspect ratio. Goodyear make a 235/55/16 - Eagle GT/HR. I am sure there will be others.
Old Jun 27, 2008 | 09:20 AM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: Tires
Well I might have found some. I am looking at Sumitomo HTR Z II in 235/60R16. They are just alittle bit more expensive than the others, but will work.
Old Jun 27, 2008 | 09:51 AM
boogerschnot's Avatar
boogerschnot
Default RE: Tires
Check out this site, Its a calculator that will help you to see the difference in sizes of tires..
http://www.rims-n-tires.com/rt_specs...size&text2=
Old Jun 27, 2008 | 10:00 AM
boogerschnot
Default RE: Tires
I dont see why a 245 wouldnt work on a 7 inch rim.. IMO
Old Jun 27, 2008 | 10:20 AM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: Tires
Thanks. I am getting the 235s though.
