monte bars
Old Jun 29, 2008 | 03:58 AM
javier146's Avatar
javier146
Default monte bars
Do monte carlo bars fit with a 351 inside a 65 stang? If so what is a good brand? Also what other items do I need other than the monte carlo bars and export brace after putting in a bigger engine?
Old Jun 29, 2008 | 04:50 AM
baddog671's Avatar
baddog671
Default RE: monte bars
It should fit, but I'd suggest a curved style just to make sure you clear the filter and dizzy.
Old Jun 29, 2008 | 11:05 AM
Starfury's Avatar
Starfury
Yeah, I suspect you'll need the curved style to clear the distributor. Nothing wrong with that, though, they're still plenty strong.
Old Jun 29, 2008 | 11:41 AM
F14chuck's Avatar
F14chuck
Also consider bigger springs for the front end. Type/size varies depending on the stance you want to achieve for the front end.
Old Jun 29, 2008 | 11:51 AM
baddog671's Avatar
baddog671
Is this an i6 to v8 conversion, or just bumping it up from a 289?
Old Jun 29, 2008 | 12:31 PM
javier146's Avatar
javier146
from a 302 which is close to a 289
Old Jun 29, 2008 | 05:41 PM
66JameStang's Avatar
66JameStang
I know it fits in a 66.
I just remembered there is a catch, if you have/want A/C you will have to make a custom bracket we are currently having to make one, and we are using a lower profile pump...
Old Jun 29, 2008 | 06:51 PM
67BullittCoupe's Avatar
67BullittCoupe
sorry to thread hi jack
but i have a 67 with AC
do i need to modify to fit the bar?
or am i safe?
Old Jun 29, 2008 | 08:37 PM
tyler72's Avatar
tyler72
See, thats my issue. I have the factory York AC compressor on my 347, and I am afraid that a Monte Bar will hit the compressor. Has anybody experienced this on a 71-73?
Old Jun 29, 2008 | 08:45 PM
66JameStang
Measure your clearance and figure out where you would install it that would be the safest way to check. Fit a fake bar the bar is pretty much even with the deck indentions and the bar is about 1" think? I suppose that would work for you to find out?
