oil change questions
my engine is all original. probably un opened from 1967 and i have the gaskets to prove it.
question is i just changed my oil iwht a synthetic blend. normally i like to run synthetic in my cars and change the oil at the same interval as a non synthetic car.
if i switch over to a full synthetic on my car will the oil find its way through the old gaskets. i will eventually replace all of them but that might not happen by the next oil changed which i have planned for in a month or two.
i run Torque Q in my old mustang and my jeep
i find that my jeep which see a lot of high rev low gear off roading abuse runs smoother and cooler with the Torque Q.
saying that, is the zinc that important? never heard of it before.
ORIGINAL: Oxnard Montalvo
The problem was the old synthetics. The new synthetics will not cause a problem. Use a diesel grade for the zinc.
Yes, zinc is very important for older flat-tappet cam engines. It's an important anti-wear additive that ismostly removed frommostoils. I recommend using Valvoline VR-1 for a non-synthetic as it's designed specifically for flat-tappet race motors. High end synthetics like Red Line and Royal Purple also have a lot of Zinc. Some diesel oil still has a high zinc content, but that won't last long since '07+ diesel vehicles all have cats now. Castrol's Delo has been switched over to the new CJ-4 low-emissions rating for months now.
i like the royal purple too. is this a good choice?
dugan, you have to flush out your engine good first with an engine cleanser.
well thats what i do. my jeep has 120k on it and weve ran synthetic since the end of the warranty. which was at 60 i think. i beat the sh** out of the jeep. surprised its still in awesome shape.
but you know each engine is different.
Eastwood makes a Zinc additive. I do not have any experience with it but it sounds like the material we need for our flat-tappets.
I am still unclear if the Zinc is needed just for break-ins or at every oil change? Any insight on this anyone?
(did not mean to hijack the thread)
ORIGINAL: mustdoc
be my guest i hi jack everyone else.
i use a off the shelf engine flush when ever i do an oil change. like Restore.
and i always add some seafoam periodically.
but thats different than zinc.
Zinc isabsolutely vitalduring break-in, but it's not a bad idea to run a high-zinc-content oil (or oil with an an additive) for the life of the engine. It acts as an anti-scuffbarrier in the case that you ever get metal to metal contact. Cam lobes like it
