AOD/Tremec
Old Jul 6, 2008 | 12:21 AM
vineman's Avatar
vineman
Default AOD/Tremec
Ok, couple inqueries here, is the Tremec trans the T-5? Did i read correctly that the AOD aftermarket crossmember work for the Tremec? I was planning on getting an AOD but the one i was getting may not be available when I get a chance to get it so I was wondering if the crossmember i bought for it would work with the Tremec.
Old Jul 6, 2008 | 12:41 AM
zmetalmilitia's Avatar
zmetalmilitia
Default RE: AOD/Tremec
From what I understand the T-5 is a T-5 and the tremec is either a TKO500 or TKO600, they are different. If I'm wrong I will be slamed. Not sure if the crossmember is interchangeable.
