O crap.... I Installed it upside down...will it work ?
Old Jul 7, 2008 | 05:05 PM
ford65stang's Avatar
ford65stang
Default O crap.... I Installed it upside down...will it work ?
I converted the brakes up front to Disc Brakes.
But after installing the brake lines. I reliezed that I installed the Brake Booster upside down. Now the Vacoom connection is on the bottom and not the top.
I would normally just fix it, but it was a pain to get the booster in place.
will it work ? [&:]
Old Jul 7, 2008 | 05:16 PM
blue66mustang's Avatar
blue66mustang
Default RE: O crap.... I Installed it upside down...will it work ?
I'm assuming that the master cylinder is the right side up...RIGHT? If so yes the booster should work.
Old Jul 7, 2008 | 05:20 PM
zmetalmilitia's Avatar
zmetalmilitia
just flip the car over and it should work fine.
ford65stang
yes the master cylinder is the right side up, so it holds fluids [8D]
im still working on the electrical so i haven't had a chance yet to fire it up yet to check... Thanks
Old Jul 7, 2008 | 06:00 PM
NvrSumR's Avatar
NvrSumR
I just installed disk brakes, master cylinder and a power booster. How exactly did you do that? Did the holes for the booster actually match up or did you modify them?
Old Jul 7, 2008 | 09:02 PM
Adrenolin's Avatar
Adrenolin
LOL How did you do that?!? We also just fitted a new brake booster and hydraulic clutch master cylinder this past week and I don't understand how you could have mounted it upside down. hehe funny really. [sm=icon_rofl.gif]
Old Jul 7, 2008 | 10:40 PM
4reboy's Avatar
4reboy
hmm maybe you got an odd booster because I thought it had a specific bolt pattern to line it up. hmm maybe not! anyway it should hold vacuum just the same no matter what position its in I would think
Old Jul 7, 2008 | 10:47 PM
flyingfool's Avatar
flyingfool
only one way to find out for sure!....[8D]
Old Jul 8, 2008 | 01:02 AM
ford65stang
I modified emm cuz it looked like it was the only way to work, I didn't drill new holes....just grinded some areas off [8D]
Old Jul 8, 2008 | 10:09 AM
boogerschnot's Avatar
boogerschnot
WTF? How did you just grind off areas and get it to fit.. The bolt holes area specific pattern.
