smooth rear interior quarter panels
Old Jul 7, 2008 | 07:41 PM
greystallion66's Avatar
greystallion66
Default smooth rear interior quarter panels
I saw someone on this forum post some pics of their ( I believe 67 or 68) burnt orange mustang. They had the rear interior quarter panels smoothed over. (instead of the textured finish that they come with) I was wondering if anyone knew his sn so I could ask him how he did it. I was told that you would have to use body filler. Is there any other way? I have never used body filler before. Any ideas? Thanks
Old Jul 7, 2008 | 07:54 PM
Tony R's Avatar
Tony R
Default RE: smooth rear interior quarter panels
You could put on a heavy coat of high build primer and sand it down if you dont want to do a skim coat of bondo. Bondo is easy to use though.
Old Jul 7, 2008 | 09:37 PM
Nick.Simonds's Avatar
Nick.Simonds
I will be smoothing mine soon, the doors too. I will just sand them smooth, I would be afraid the bondo would crack from arms hitting the panels.
Old Jul 7, 2008 | 09:39 PM
Tony R's Avatar
Tony R
you arent putting enough bondo to worry about cracking. You are only trying to fill in the texture. That is why I said you could use a high build primer. That might be you r easiest way.
Old Jul 7, 2008 | 09:43 PM
greystallion66
Where can I buy this high build primer? What makes the high build primer different from normal primer?
Old Jul 7, 2008 | 10:00 PM
Tony R's Avatar
Tony R
you buy it at an auto motive paint store. It is used when doing your body work. It goes on a little thicker so that you can sand it down to remove sanding marks and other minor imperfections. Use it whenyou are blocking your car down for a smoother finish. It is much easier to sand than bondo
Old Jul 7, 2008 | 11:06 PM
rst08tierney's Avatar
rst08tierney
heres some pics......everyone already answered. Its a high build primer. Good luck, it well worth it for the end result. I used the high build on the doors as well. Sorry about the small pic but the uploader still is on the brink
[IMG]local://upfiles/66615/B076C0154ACA4767AD89B7774A90B90F.jpg[/IMG]
Old Jul 7, 2008 | 11:09 PM
rst08tierney
Old Jul 7, 2008 | 11:36 PM
greystallion66
perfect rst08tierney. Thanks a bunch. Love what you have done with the car and the roll bar. AWESOME.
Old Jul 8, 2008 | 08:52 AM
67BullittCoupe's Avatar
67BullittCoupe
rst08tierney how often do you drive yoru car? how does teh paint hold up to abuse by passengers, it looks awesome and i wouldnt mind doing somthing similar but mine is a daily driver and im worried that a smooth shiny finish would get chipped or scratched much easier.
