vibration
Old Jul 8, 2008 | 02:18 AM
groho's Avatar
groho
Default vibration
Wanted to get input from the long time 64-66 owners. Got what feels like a driveline vibration, nothing major, just annoying as heck, increases with speed. I've read multiple times that the 64-66 have an inherent driveline or motor vibration. Is this true? In the last two years I've replaced all major components; driveline, rear end, suspension, wheels, tires, etc. Is this something I gotta live with, or doI start isolating the issue; neutral driving, rotate tires, etc. My gut tells me the shop did a suck job on the wheel balance.
Old Jul 8, 2008 | 02:20 AM
Carlos Pineiro's Avatar
Carlos Pineiro
Default RE: vibration
Motor mount misfunction?
Carlos
Old Jul 8, 2008 | 10:38 AM
LPlum's Avatar
LPlum
Hey groho, when you refered to driveline, did you mean driveshaft? Try unbolting the driveshaft and turning it 180 degrees. Or take the drive shaft into a specific driveline company. Have them check its balance.
Lowell
Old Jul 8, 2008 | 10:41 AM
davesanborn's Avatar
davesanborn
It's always best to start with the simplest things first....
U-joints?
Tire/wheel balance?
Transmission mount?
Rearend housing U-bolts tight? Has the alignment bolt in the bottom of the leaf spring pack worn/sheared off?
Dave
Old Jul 8, 2008 | 11:00 AM
Starfury's Avatar
Starfury
Nobody's asked the basic drivetrain vibration questions yet...
What speed does the vibration start? Does it stop at a certain speed? Does it vary with speed or rpm? Where does it feel like it's coming from, the steering wheel or the seat of your pants?
Old Jul 8, 2008 | 11:10 AM
UH60LCHIEF's Avatar
UH60LCHIEF
ORIGINAL: LPlum
Lowell
+1
Ballance the tires (cheap) then DS (also cheap). Then check the mounts. I also had the harmonic ballancer let go on mine, not all the way, but enough to annoy the crap out of me. It looked okay, but sure enough when I replaced it voila! No more vibration. That one took me a while to figure out. It was a pretty mild vibration tho. The DS was VERY noticeable. Replace the u-joints and have them ballance the whole DS as an assembly with the yoke. When I did that the car got smooth as glass. Another possibility although less likely is a wheel bearing, but usually there's a noise associated with that.
Old Jul 8, 2008 | 08:49 PM
Mustangdemon67's Avatar
Mustangdemon67
my guess is bad u joints
Old Jul 8, 2008 | 09:48 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
If it's a stick there is always the transmission pilot bushing.
If it's a slush box- never mind.
Old Jul 8, 2008 | 11:57 PM
Gun Jam's Avatar
Gun Jam
It could be bent axles. I had a bent axle it had about .011 run-out...made a very noticeable vibration. The easiest way to check is at the hubs were the lug bolts fit through. Run a dial indicator on the outside edge of the hub and see if its more than .003 run-out
-Gun
Old Jul 9, 2008 | 06:57 AM
67 evil eleanor's Avatar
67 evil eleanor
I like the checking simple things first. On the tires, I would have them "road forced" balanced and see if they fall into specs. The last one I chased down ended up being the tire out of round, not so much out of balanced. Like having an egg on the rim. Once I did the road force and changed the BAD (and NEW Eagle F1's) tires, the vib issue is gone. Also this will check rim runout, that can be a problem also and it seems that steel stamped rimsare worse. After you do that, then go to the next step. This may help.
http://www.armorb.procarcare.com/inc...04/4fig15.html
